+ cmcraeslo
I assume that you are talking about DC and not AC power. Also, can you post the maximum current that the LM consumes.
The force is calculated by I * number of turns, where I is the current flowing through the coils.
Rather than reduce the number of turns and use heaver gauge wire, which would be problematic, why not use a switch mode power supply to convert 12V to 30V.
