Author Topic: Temperature Sensor drawing High Current  (Read 1603 times)
Offline spiderTopic starter
« on: August 08, 2017, 05:55:46 pm »
Hello,
I have a problem with my electronics project.
Parts:
  • "Arduino" Nano
  • BME280 on PCB
Datasheet: https://www.bosch-sensortec.com/bst/products/all_products/bme280
Here is an image of the PCB because I don't have a schematic.
(Pin order: SDO; CSB; SCL; SDA; GND; VCC)
The sensor is directly connected to the Arduino via i2c and powered by the Arduino with 5v.
  • 5V --> VCC
  • GND --> GND
  • A5 --> SCL
  • A4 --> SDA
I am using this library to control the sensor:
https://github.com/adafruit/Adafruit_BME280_Library
According to the datasheet it should draw max. 0.3 µA in sleep mode.
Yet I am measuring these currents and voltages:
  • VCC 420 µA
  • GND -40 µA
  • SCL -194 µA
  • SDA -201 µA
  • Reference is the VCC pin
  • GND -4.7 v
  • SCL -3.79 v
  • SDA -3,76 v
The high current flow is particularly bad because it is probably generating a lot of heat within the temperature sensor.
I have no idea what is causing the high current flow. To me it looks like that there is too much current flowing over the data lines.
« Last Edit: August 08, 2017, 06:01:38 pm by spider »
Offline floobydust
Re: Temperature Sensor drawing High Current
« Reply #1 on: August 08, 2017, 07:18:08 pm »
BME280 is not a 5V part  :(  It runs off 1.7-3.6VDC so you probably damaged it.
VCC should connect to +3.3V on the Arduino PCB.
« Reply #2 on: August 08, 2017, 07:32:07 pm »
Changed it back to 3.3v. Sensor ist still working fine.
At 3.3v I can break the GND connection and it is still working. :o
I'll measure current and voltages tomorrow.
Offline floobydust
« Reply #3 on: August 08, 2017, 09:39:10 pm »
It looks like your PCB does not have a I2C level-translator (3.3-5V), instead only using 4k7 resistors. Most BME280 boards have IC/MOSFETS for this.
So -ve currents will flow when 5V TX happens feeding into 3.3V part with 4k7.
The sensor has many modes and you can change the sample rate, filtering to lower current drain.
I found the Adafruit BME280 Arduino library gave high temperature readings. Several degrees C higher than should be read  :-//
It might have a bug reading the calibration table for temperature. Tried another library and it was better. Bosch's C code is heavy on floating point for an Arduino.
Let me know how your temperature readings are.
The BME280 is sensitive to light, no bright light while reading it.
« Reply #4 on: August 09, 2017, 04:19:32 pm »
I am sampling the sensor quite slow at 0.5 Hz and 16x oversampling for temperature and pressure.
It is reading 0.5°C higher than my ±0.5°C reference thermometer at 5v. On the other hand it is reading ±0.1°C at 3v compared to the reference thermometer.
At 3v I am now measuring these currents in sleep mode.
  • VCC -40 µA
  • GND 0 µA
  • SCL 20 µA
  • SDA 20 µA
-40 µA and 0 µA looks weird to me. While the sensor is reading the VCC current turns positive and the data lines negative. GND stays zero.
