Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Transformer behavior
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Transformer behavior (Read 1678 times)
Shock
Super Contributor
Country:
on:
May 16, 2016, 11:51:26 am »
Can anyone describe whats causing the flattening of the peaks on the top waveform at about 17:10?
Logged
Multimeters: Fluke 189, 87V, 117, 112
>>> WANTED STUFF <<<
Monadnock
Contributor
Country:
Re: Transformer behavior
Reply #1 on:
May 16, 2016, 12:27:16 pm »
Current only flows at the peak of the AC sine wave when the caps are charged. The impedance of the transformers is high enough that the voltage drop across this impedance during the charging of the caps causes the top of the AC sine wave to get cut off.
Logged
Circlotron
Super Contributor
Country:
Reply #2 on:
May 16, 2016, 12:42:18 pm »
Yep. The transformer has no load on it until it's voltage gets as high as the capacitor voltage. Then it has to work! The transformer voltage still rises a little after this, and during this time it is pulling the capacitor voltage up a little too.
Logged
basinstreetdesign
Frequent Contributor
Country:
Reply #3 on:
May 17, 2016, 12:06:47 am »
Yes, but only when the load resistor is drawing current. If the load were removed then the sine wave peaks would spring back up and the ripple voltage on the load would disappear. Since no current is drawn by the load then none (or almost none) is delivered by the transformer/rectifier combination to the cap.
Logged
STAND BACK! I'm going to try SCIENCE!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
