One thing to note about screws that really annoys me. They usually come either with plain slot head drives, or with Phillips drives.
Slot heads are just ugly: they the screwdriver has no grip on the screw, the bit is not self-centering, and the bit will easily cam out if not precisely centered and aligned. The slot head is horrible.
Phillips screws are barely any better. OK, the bit is self centering, and it can hold the screw to some extent, but the damn thing was designed to cam out of the screw head. The wretched screws were designed to be single use, to get churned up with the screwdriver, and to be hard to tighten or undo. Someone patented a deliberately bad design and got everyone to use it! WTF!
So of course, there must be a better alternative, right?
One is the Pozidriv head, but good luck finding any of those in the USA (or screwdrivers to match).
Another is the square recess Robertson design. These have almost no disadvantages in use, but they are also very rare in the USA. You find them most often in wood screws.
