RS232 outputs are current limited (at least they should be if by the standard, and all chips a know do limit the current). This way the RS232 is protected from shorts too. The current is likely not enough to damage the ethernet input transformer. Also input impedance on ethernet is much lower, so there will not be a high voltage.
So normaly there should not be any damage, but I have noch tested or in detail looked at the ethernet specs.
