We have a couple texts, "Research Perspectives on Dynamic Translinear and Log-Domain" (Kluwer Academic) by Serdijn and Mulder 2002 which is a collection related topics. Another is "Design and Analysis of Integrator-Based Log Domain Filter Circuits" by Roberts and Leung 2000 (Kluwer) which is a good reference for Log Domain Filters. Dr Robert Fox at University of Florida was also instrumental in development of Log Domain Filter synthesis & design back around 2000.
We developed a high order tunable lowpass filter chip in IBM 8HP SiGe BiCMOS (utilizing the superb SiGe bipolar transistors as log and exponential functions) back around 2000. The goal was to improve on-chip DR for active filters by utilizing the log compression of the input, then filtering by selective scaled integration, then subsequent expansion with the exponential function. The math behind filter type translation into the Log Domain is quite involved, and only trivial for simple 1st and 2nd order filter functions. What's intriguing is the filter function gets scaled in frequency linearly by the active device integrator bias current (collector current), and with good bipolar transistors this can scale many decades.
Recall this was an 8th or 9th order Inverse Chebyshev LPF, current tunable over 5 decades to ~600MHz but the overall filer noise figure was compromised.
The input signal and its' noise get compressed by the log function, and during the filter analog computations, active device noise as well as other internal noises contribute to the log domain signal path noise, similar to how active and passive devices contribute noise to a conventional active filter. However, upon output signal expansion by the exponential function back into the Linear Analog Domain, the signal noise which was compressed along with the signal itself at the Log input gets expanded, but the internal log function noise sources also get the same exponential expansion (they were not compressed by the input Log function, and thus higher relative to the input signal)) and subsequently corrupt the overall filter output SNR. Believe this is the fundamental reason Log Domain Filters never really caught on, they had poor overall NF.
BTW back then the IC simulators didn't handle noise properties very well in the time domain, especially with log compression and exponential expansion, one of the many reasons we and others began looking into Time Domain Noise Analysis simulations.
Anyway, this was an interesting adventure back then when we were trying to improve on-chip analog signal processing, and worthy of looking into for folks interesting in Log Domain circuits and functions.
Best,
