another thing, the IC is a 6A buck, so its not the jellybean cheap type. probably heat is one issue. with original ic, heat can dissipate through bottom/heat pad as shown in picture, with bodge wiring and external module that cant/incompatible with original footprint, this issue must be carefully observed, extra heatsink if necessary, fwiw..
