Hi guys, realized I never updated this post.
I found the source of the problem, it was the VB supply line. I added some additional power filtering, and the noise is almost non existent. I duplicated when I have on the main VCC rail (100ohm resistor and 220uf cap to ground) on the VB rail and that cleaned it up nicely. I also added some local VB bypassing the new PCB revision. We will see if that helps.
Even though the issue is solved, I want to reply to a few comments with some additional thoughts, and lessons learned.
Set the scope up for a match waveform, and use the filter function, LPF, cutoff of
5 Hz, and measure the period of the waveform. Looks like you get ~ 3 cycles in 200mS
per div, or 60 mS per cycle, or 16 Hz.
Any room environment stuff going on, like a flourescent light starter cycling trying to
start a light, just guessing.
Any RC time constants look like 60 mS ? Possible oscillator parasitics.
Last thought is it a feedback loop via Guitar amp driving speaker and induced power
draw affecting mains and the power to the OpAmp circuit.....?
Regards, Dana.
Hi Dana
I think a nice variable LPF is on the list of test equipment to buy, because my scope doesnt have one
Nope, all of the noises in the room electrical system have been pretty well isolated.
Thanks for the ideas, I will add them to the list of things to check for in opamp circuits.
The datasheet lists the noise at a typical level of 18nV/root Hz which is better than a lousy old 741 opamp but not as good as an OPA2134 dual opamp with only 8nV/root Hz.
The datasheet has a graph showing the noise rising below 400Hz which causes the rumbling noise that happens in all opamps.
Get a better opamp or turn down the gain.
I replaced it with an ne5532. That helped significantly with the hiss. I have found that I really can only use the tl072 in very low gain or buffer style configurations, otherwise the noise is very audible. I really want to get a decent audio analyzer in the next 6 months so I can directly measure th noise performance of opamps.
Nobody has called it out yet, so I'm guessing it's not a problem... why is it ok for those opamps to be directly driving such large capacitors? I can't find mention of output capacitance in either datasheet.
I am using them to block DC in surrounding stages. Guitar amps dont like 4.5v DC on the inputs.
