Author Topic: Is the compensator output on DSO protected?  (Read 4145 times)
Offline truhlik_fredy
« on: February 19, 2011, 01:36:29 pm »
At the moment I want for one-off usage (perhaps 20minutes) a simple function generator. And I have Rigol DS1052E, there is the compensator output for adjusting probes. It's 1Khz and its suits my needs very well. But I don't know how well its protected, like when I will draw to much current, or short it out. The device should not draw much current but just for the case. Its silly idea and I don't want to regret it.
Online Simon
  • Global Moderator
    • Simon's Electronics
Re: Is the compensator output on DSO protected?
« Reply #1 on: February 19, 2011, 02:05:21 pm »
well as mine mysteriously does not work anymore I would say no. My only explanation for mine is that I accidently shorted it. I suggest using a buffer just to be safe, Failing that throw a 555 timer circuit together or use an MCU
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
« Reply #2 on: February 19, 2011, 04:25:19 pm »
I will make MCU one, just I had this lazy evil thought to make shortcut and use the compensator for it. Thanks to turning me back :D (i was close :) )
Online Simon
  • Global Moderator
« Reply #3 on: February 19, 2011, 04:28:16 pm »
yea you best use and MCU, it is as easy as flashing a led, no point in risking blowing your scopes calibrator, I've done that somehow
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #4 on: February 20, 2011, 04:44:59 pm »
But if 1 kHz is all you need, just isolate the Rigol's calibration output with a voltage follower op amp to provide driving output to your load.  For this app you can use any op amp you have that is anywhere like a 741.
But if you do have an op amp handy, just make an oscillator with it, and save your worry:
If you don't have an op amp, you aren't picky about the output waveform, you can make an oscillator with any one of at least a transistor, op amp, or logic gates, and then at least a capacitor and some resistors.
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/square.html
Best Wishes,
 Saturation
« Reply #5 on: March 04, 2011, 04:08:44 am »
Thanks, I was thinking about something like that but I was afraid that I can touch the ground near by the compensator output and I will short it before it goes to voltage follower. But thanks anyway.
Offline tecman
« Reply #6 on: March 04, 2011, 03:26:56 pm »
Op amp circuits are nice, but you ideally should have as fast a rise time as practical.  Make a simple oscillator with a 74HC04, buffer it with a couple of more inverters in the HC04 and you will have a nice fast rise source.
paul
