Good Morning l3gi0n,
Your budget is an important factor in deciding a DMM.
If you can afford $220 then the Brymen 869s will serve you well.
Others will disagree, but that is my opinion.
DMM recommendations are probably the most common topic on the forum along with oscilloscopes, so pooch around in the search function and you will find more recommendations than
you can shake a stick at.
Good luck with your choice, (by the way, what is the brand and model of the 'cheapy' that you have now?)
