Okay.
So it took only a moment to verify that your fix (insertion of that resistor) works, and a bit longer, due to simulation run times, to verify it works really well. I had been experimenting with BE bleed resistors across one or both of those transistors in the SCR, and that worked, but the circuit was very sensitive to component values; when I changed the value of the current source, it broke, and I'd have to tinker the bleed resistor values. Also, the bleed resistor across the pnp was allowing current from the right hand divider to contribute to charging the cap, resulting in my nice straight ramp bowing upwards. So your fix solves all of those problems. I can vary that current source wildly, to change the frequency of the sawtooth, and it continues to work.
My current issue is I don't really understand *why* your fix works. The various sources I've found on "make your own SCR" don't discuss anything similar to that. Can you illuminate me on this, please? I'm struggling toward jedi, er, BJT mastery, but obviously have a way yet to go... could it be something subtle like changes in beta with varying collector current? (Guessing wildly here.) Thanks!
