Author Topic: What kind of 4-pin volumer controllor is this ? Or is it broke  (Read 1758 times)
Offline lordvader88Topic starter
« on: January 18, 2018, 08:13:46 pm »
I have a volume knob off a panasonic stereo, it has 4 terminals, looks like a pot, however its the type the turns forever in both directions. 2 pins are on the same PCB trace. AS I try to measure the resistance , is either open, or shorted, for every degree of turning basically. And it must have cap in it too, because if its not open or short when I stop turning it, it will be about 4-5 ohms, and start dropping down to zero.
So what is it ?
Online Benta
Re: What kind of 4-pin volumer controllor is this ? Or is it broke
« Reply #1 on: January 18, 2018, 08:21:17 pm »
It's a rotary encoder. Most likely quadrature output. The volume control itself is somewhere else, digitally controlled from the encoder.
« Reply #2 on: January 18, 2018, 09:33:33 pm »
ok nice...
