Author Topic: Is their a difference between Kester and MGchemicals?  (Read 4917 times)
Offline unluckygamerTopic starter
  • Country: pa
« on: July 12, 2018, 01:28:37 am »
I am looking to buy a small pack of solder. I am looking for a 63/37 0.031" diameter solder. My two options right now is kester and mgchemicals with MGChemicals being a bit cheaper.
I am wondering if their is any big difference.
« Last Edit: July 12, 2018, 01:38:45 am by unluckygamer »
Offline Nusa
Re: Is their a difference between Kester and MGchemicals?
« Reply #1 on: July 12, 2018, 05:01:38 am »
Assuming you pick solders with similar specifications, I expect you'll get similar results. Both companies have a good reputation for quality.
Offline james_s
« Reply #2 on: July 12, 2018, 05:40:59 am »
Just make sure whatever you get is the real deal and not counterfeit product from China, I wouldn't worry about the brand, the result should be almost identical.
Offline drussell
  • Hardcore Geek
« Reply #3 on: July 12, 2018, 12:50:06 pm »
Quote from: unluckygamer link=topic=121859.msg1665515#msg1665515
Sure...  One says Kester and one says MG Chemicals on the label.  :)
From a usability-for-soldering standpoint, no, not really.  Both are good solder.  So is Multicore brand but I don't see it in the local retail stores as often lately.
My last couple 1lb spools of Multicore that I use for general purpose are getting low so I will be needing to restock soon but the last time I had to replenish my stash, 1lb spools were still $9.99-14.99 (retail!)...  It's going to be an eye-popping expense this time, even wholesale.  With the prices these days, I really wish I had bought caseloads back then.  :)
Offline james_s
« Reply #4 on: July 12, 2018, 04:28:15 pm »
Yeah no kidding, I've just about used up the 1lb spool I bought ages ago, must have been over a decade. I haven't looked at prices lately but I know it's going to be a shock.
Online Bud
« Reply #5 on: July 12, 2018, 04:36:23 pm »
I used both and to me Kester is noticably better. I cant find Kester here beside on auction web sites so appears MG dominates in Canada. I would take Kester any time over MG, both wire solder and SMT paste. MG is not bad but Kester is the best.
Offline drussell
  • Hardcore Geek
« Reply #6 on: July 12, 2018, 04:43:03 pm »
I think a lot of it comes down to personal preference and what you're used to.
Digi-Key stocks MG, Kester and Multicore.
Online Bud
« Reply #7 on: July 12, 2018, 04:55:29 pm »
[quote author=drussell link=topic=121859.msg1666520#msg1666520 date= general purpose are getting low so I will be needing to restock soon but the last time I had to replenish my stash, 1lb spools were still $9.99-14.99 (retail!)...  It's going to be an eye-popping expense this time, even wholesale.  With the prices these days, I really wish I had bought caseloads back then.  :)
[/quote]
Keep checking Kijiji, you can get a big spool from electric supplies surpus sales, but even there if you calculate price per Lbs it is not much cheaper than retail.
Offline GigaJoe
« Reply #8 on: July 12, 2018, 07:17:01 pm »
have kester, aim alloy, Mg chem., all of then 63
equally all the same .... but kester somehow produce the most shiny surface.
and flux ... some I saw acid based, some no clean, some rosin, some organic thingi
Offline james_s
« Reply #9 on: July 12, 2018, 09:25:51 pm »
The flux is probably the biggest difference from brand to brand, I would think that by now metallurgy is advanced enough that it is not difficult to get a reasonably pure and consistent mix of tin and lead.
Online David Hess
  • DavidH
« Reply #10 on: July 12, 2018, 11:33:07 pm »
For other chemicals like fluxes, thinners, and cleaners, the big difference I have found between Kester and MG Chemicals is that Kester is not available in small quantities anymore.  I used to be able to buy 4 ounce bottles of Kester products but not anymore.
As far as the solder, make sure to wipe down the outside to remove contamination and oxides as you use it.
Offline james_s
« Reply #11 on: July 13, 2018, 01:09:53 am »
Hmm I've never done that, I'll have to give it a try and see if it results in nicer joints.
Online David Hess
  • DavidH
« Reply #12 on: July 13, 2018, 02:10:00 am »
It is usually not that big a deal but there is a reason they recommend using fresh solder for production.  Using fully activated rosin flux helps with old solder also.
