Hi
I build R/C model boats .
The speed controller in the boat ( ESC ) can be made to run as forward only or as fwd/rev with center stick as off
however my transmitter doesnt have a self centering stick so finding the middle quickly when in a panic
is not easy and a crash is the likely outcome , At 70 years old I dont think so quick as I did
With the ESC set for forwards only using the throttle its easy , I just pull the stick right back , no fidling to find ther middle and the boat stops but then you get the
problem of if you are in a corner you have no reverse to back out
The motor in the boat is a brushless one ( 3 leads) . I know I can switch any two leads and the motor will reverse so 2 changeover relays , one for each of the two motor leads
on another channel makes for a simple reverse switch , but the motor has a maximum current draw of 40Amps and if I forget to shut the throttle first
before activating the relays I fear the contacts would soon weld together, , and what happens if one relay is a bit sluggish, wont I get a dead short?
I am thinking I could maybe do the job with two powerfull mosfets but how to wire them I am not sure , or even maybe an H bridge could it be done that way?
Any circuit ideas would be great either for mosfets or H bridge , or if you know an even better way then great
Regards
Don
