Hello.
I'm making a flyback power supply, which delivers 50mA @ 200V from 5VDC supply.
Currently I'm using DC/DC boost circuit to generate 12V from 5V, which is used to drive UC3843, which in turn, drives a beefy mosfet, which is directly hooked to 5V rail and everything works fine. However, I'd like to reduce count of parts, and skip DC/DC booster somehow. I tried to use a lower voltage PWM controller, like MCP1632. It works fine, but it's output is designed for driving logicl level mosfets, and it can't really handle my IXTQ82N25P mosfets.
So the question is, maybe there is an low voltage (5VDC) PWM controller, which has built-in boost circuitry, so can drive big mosfets directly?
