Author Topic: Is there a particular reason Japan is 100 volts?  (Read 17741 times)
Offline filssavi
Re: Is there a particular reason Japan is 100 volts?
« Reply #25 on: August 30, 2018, 04:28:13 pm »
I Know full well of HVDC however it is used only for transmission not distribution,and in particular  the biggest transmission lines are hvdc(basically the ones tying multiple grids together) as the conversion station are extremely expensive, also the voltage is much higher 500 to 800 kV
the distribution grid (Medium voltage and lower) are exclusively AC and they will stay so for the forseable future (transformers there are still the king of the hill)
as for appliances, you would have been right 20 years ago, however now in europe everything (apart from the cheapest chinese crap) is inverter fed, from whasing machines, to expecially AC units, the older on/off type are getting more and more difficult to find.
so to run motors you first take AC rectify it to DC and then syntethyze AC back up. direct 50 Hz machines are already disappearing, especially the single phase ones (that are the worst anyway), this is mostly to get AAA++ efficiency rating, that consumers are quite sensitive on
for the same reasons induction machines will be slowly (again slowly) be replaced in most applications by synchronous machines, BLDC/PMSM for the high end, and synchronous reluctance for the low end
Offline bsfeechannel
« Reply #26 on: August 30, 2018, 04:40:43 pm »
Not as exciting as what they do in Brazil!
What do they do in Brazil?
https://www.worldstandards.eu/electricity/plug-voltage-by-country/brazil/ ?
Well, blame Canada! Literally.  :D
The two standard voltages used in Brazil are the result of the history of its electrification, which started in the 19th century. Back then, as anywhere else in the world, electrification was carried out by many small private companies, each with their own standard voltages and frequencies.
127V roughly reflect the places that were electrified first. And many of them were serviced by the, then Canadian-owned, São Paulo Railway, Light and Power Ltd., popularly known simply as Light, with its 110V standard. Up to this day people  refer to 127V installations by calling them 110 installations.
Other regions were electrified by different companies a little later with 220V (phase-neutral).
Up to the 60s there were two frequencies, 50 and 60Hz. Now the standard is 60Hz.
If Light's standard back then was 110V, why 127V now? Well, there were other "standards": 100, 115, 117 and 120V. 127V is a compromise solution that's easy to obtain from a 220V three-phase Y circuit (220V ≃ 2* 127V * sin(60°) ). So most places where you have 127V (phase-neutral), you can also have  two-phase 220V (phase-neutral-phase) or three-phase 220V with a neutral.
Why don't Brazilians standardize 220V, once and for all? Because they spent all their money converting their units to the metric system.   ;)
Offline boffin
« Reply #27 on: August 30, 2018, 05:08:44 pm »
And of course, there were also some system voltages that simply died out over time. Isn’t there still some weird low-frequency AC in some parts of USA for industry or something?
You mean like Switzerland's (and also Austria's and Germany's) 15 kV, 16.7 Hz railway overhead wire voltage?
Railways are wonderfully unstandardized, The UK for example uses
25kV @ 50Hz (overhead)
750V DC (3rd rail)
1500V DC (3rd rail)
630V DC (3rd/4th rail +420/-210)
Gets even worse when you get to Spain which not only has differing voltages, but even differing rail gauges
Offline Gyro
« Reply #28 on: August 30, 2018, 05:29:15 pm »
Electrolytic corrosion can be another issue for DC distribution. For instance, the London Underground uses the insulated center 4th rail as the return path for DC traction current rather than the running rails (as is done on above ground systems). This was done to prevent electrolytic corrosion of the surrounding pipes and cabling (mostly pipework I suspect).
Best Regards, Chris
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #29 on: August 30, 2018, 05:31:51 pm »
... When British Imperial was better, halve something again and again to get exactly 1/2, 1/4, 1/8, 1/16, 1/32 etc. It's soo much easier than dividing by ten! >:D
Offline jmelson
« Reply #30 on: August 30, 2018, 06:50:09 pm »
Niagara Falls used to generate 25 Hz and parts of New York City continued using it up until the early 2000s.  I'm pretty sure it is gone now since the hydro plant stopped making it in 2006
This was sent a lot farther than New York.  We had a converter station in St. Louis, MO that created ~60Hz from the 25 Hz Ontario Hydro power, for use in large downtown buildings.  They also apparently used the 25 Hz directly for elevators, etc.  This was in use into the 1980's at least.  The May company (department store chain) had a data center there that was fed from THREE different substations, and the wild ground potentials caused all manner of trouble, including cables that got too hot to touch, and people getting knocked to the ground when plugging or unplugging cables.
Jon
Offline Benta
« Reply #31 on: August 30, 2018, 07:40:17 pm »
The real reason that Japan has 100 V is fascinating and has nothing to do with technical reasons, but in fact mirrors the electrical history of Europe and the US in the early 1900s where consumer electricity started becoming prevalent.
In those days, electricity was supplied by local utilities, who also supplied lamps and other electrical goods to consumers. Every utility had their own plugs and voltages to avoid competition. There was DC, AC, different frequencies etc.
In the US, this was relatively quickly conglomerated under a few large companies, eg, Edison, and standardization took place to a large extent.
In Europe, the same thing happened, although somewhat later in the '20...'30s, where electricity supply became a national issue. Still, foreign competition was unwanted, which resulted in every European country having their own mains plugs and often different voltages, eg, 110, 220, 240 V.
Same thing with Japan. We're talking the early years of Japanese industrialization here, and overseas competition was extremely unwelcome. By choosing 100 V, Japan was certain that no overseas lamps or bulbs would work on their grid.
Protectionist times; alas, it seems they're coming back.
Offline schmitt triggerTopic starter
  • Country: mx
« Reply #32 on: August 31, 2018, 01:01:03 am »
Thanks for all your replies.
Indeed, voltage selection is a little arbitrary, but most countries have somehow standardized to either of the two major standards.
But Japan, perhaps to provide a competitive advantage to its own home industry, kept the slightly odd voltage.
Offline tkamiya
« Reply #33 on: August 31, 2018, 08:56:31 am »
I have an electrician's license from Japan.
Despite that, it was never mentioned why 100 volt.  To me, 115 volt, 120 volt, and all that other voltage seems odd.  100 seems a good round number to me.  Makes calculations easier.  Also, typical single apartment feed is 20amp.  Homes may be little higher like 40amp.  We only have one or two circuit breakers.  All heavy duty appliances are gas or kerosene.  At least back when I was there in 80s, air conditioning was not common.  Power consumption and transmission from technical stand point weren't a big deal to me.  Besides, power feeds to poles were either 3300 or 6600 volts, depending on height of the pole.  Pole pigs converted them down right near our house.
Offline 6PTsocket
« Reply #34 on: August 31, 2018, 06:15:12 pm »
And then we sort of snuck up to 120. A lot of old stuff was 110 and then 115 or 117. In the real World in the US , today it is a few volts higher than 120 in some places
Sent from my SM-G900V using Tapatalk
Offline glarsson
« Reply #35 on: August 31, 2018, 06:22:21 pm »
In a couple of years the US will have reached 230V. This stepvise increase is a trick to fool everyone into the new world order.
Offline 6PTsocket
« Reply #36 on: August 31, 2018, 06:28:53 pm »
The only switch that would kind of make sense with the current state of power electronic would be to switch from AC to DC for distribution, not regular transmission, there AC is still going strong for now.
The great majority of loads right now (I don't have numbers but I bet is over 80% of the total residental and small industrial installed power) rectify the AC to DC anyway, and especially in residential use the conversion efficiencies are quite low.
switches will get bigger but they are being replaced by semiconductors anyway
Circuit creakers will get bigger, but it is not the end of the world
Unfortunately this will probably never happen since the costs would be way to high and so we will keep 240V/50Hz or 120V/60Hz forever I think
That mught be OK in a switching power supply that rectifies as a first step but any low voltage DC device with a linear supply would need an inverter to go back to AC to step it down or up for higher voltage. It is the ability to transform voltages to different  values, like down from high tension transmission  lines, with low IR losses, that helped doom DC transmission, in spite of Edison killing a lot of animals and inventing the electric chair to demonstrate the dangers of AC.
Offline basinstreetdesign
« Reply #37 on: September 01, 2018, 02:03:13 am »
Jon
More than Niagara Falls.  When I worked in a (failing) gold/copper mine in South Porcupine, ON near Timmins in Northern Ontario in 1971, half the place was on 25 Hz and half was on 60 Hz.  They had an electrical plant that was very impressive with 25 Hz rotating machines sunk halfway into the floor.  Even then they were as tall as me.  They rotated at something like 125 RPM.  There was a famous light bulb there running on 25 Hz that had been in service since the middle 1920's.  The whole place is gone now.  Just before the surface mill was to be torn down the local librarian/historian was invited to come, take anything he wanted to preserve.  He was given all of 24 hours.
« Last Edit: September 01, 2018, 02:05:08 am by basinstreetdesign »
STAND BACK!  I'm going to try SCIENCE!
