Ok, the title isn't long enough to properly ask what this thread is about so...
Is there any type of electric motor which, unlike the usual scenario, can give a large holding torque with minimal current requirements and then consumes power primarily as a consequence of providing higher speeds?
Particularly because when you consider a motor which is holding a position, it is not doing any work over time, it is just holding against a torque load (say a pulley or something), so at the level of an overview of the system, torque at low speed should not require a power input. As soon as you start moving against a torque you must consume power, but at standstill the power a motor consumes simply to apply a torque is simply being wasted as heat.
To consider some motor types which given counterexamples to the type for which I am wondering about the existence of:
A DC brushed motor has torque, current and speed relationships which mean, powered from a constant DC voltage, it draws the least current when not loaded and spinning at maximum speed. Increasing the torque load it is moving slows it down and increases the current required, right up until stall, where you get maximum current at zero speed.
A stepper motor is set with a given level of current, often fixed by typical chopper driver units with microswitches but this could be varied according to commands, which gives a given level of torque. Running faster requires a greater voltage in the motor's coils to overcome back-emf, until some high speed threshold beyond which a given power supply can no longer supply enough power to provide both the desired current level and necessary voltage at the same time. The motor, unlike a DC one with constant voltage driving,is consuming power power at higher speeds, if you consider a fixed current level, but... this is still a situation where having a higher level of current in the first place often takes more power than achieving higher speeds but with lower currents. In the motor itself, holding torque requires just as much current as torque at greater speeds, in the system of the motor and driver the power requirement rises with speed for a given level of torque, but at low speeds the level of torque required is having more influence usually than the speed.
A brushless permanent magnet synchronous motor, whether driven with AC waveforms or with DC type six step commutation, can have controlled levels of current supplied to its coils so as to control the torque produced. Considering a situation where the driver system is closed loop and knows the rotor angle, so can always energise the phases in the right fashion as to provide the maximum torque per amp... The current required, at a zero or low speed, is in proportion to the level of torque being generated by the motor. Where you've got buck-converter style driving circuits providing lower voltage higher currents in the motor, from a higher voltage lower current supply, your power requirements, for the higher voltage supply supplying the driver circuit, for a given level of torque, increase with speed as back-emf rises. Like the stepper though, and afterall a stepper and BLDC driven can be pretty similar in principle, at a given speed, or at standstill, producing a greater torque requires a greater current in the coils and a greater amount of power from the supply. Again, the amount of extra power from the supply needed so as to produce more torque is often higher than the amount needed to simply provide higher speed against zero or minimal load torque.
AC induction motors have unstable regions at low speeds, so struggle with providing torque at a standstill. This doesn't sound like the sort of scenario where a motor could be at its most efficient at zero to low speeds.
Lets ignore reduction gearboxes, as they simply shift the "problem" and let you get higher torques and lower speeds at their output whilst not changing the principle that greater torque requires more motor power, even when that torque is applied at standstill.
Is there then, any electric motor type where, unlike the examples above, you're able to hold at a standstill "for free", where the power consumes is in proportion to torque*speed, so you'd be looking at situations where a high torque at low speed, up to whatever level the system can physically deliver, needs only as much power as a running at high speed with a low torque?
This idea of a motor which gives torque "for free" (not actual zero power usage, there are always losses somewhere from every system, but "free" as in insignificant when compared to operation at speed) but then consumes power as greater output speeds are demanded would also include motor types which consume power according to torque*speed^n, so increasing the speed demands extra power more quicky than increasing the torque does. That is to say, motor types that, opposite to a simple brushed DC motor, could become inefficient at speed, but would be very efficient to provide torque at standstill.
Does such a concept exist?
Thanks
