Author Topic: Is there any reason to not use bypass caps?  (Read 10039 times)
Offline Dago
    • Electronics blog about whatever I happen to build!
Re: Is there any reason to not use bypass caps?
« Reply #25 on: September 09, 2014, 04:33:44 am »
Doesn't this has to do more with your voltage regulation?
If you can hit the core voltage then do you need bypass caps?
Not really no. With fast transients (such as caused by lets say digital edge transitions which can have a bandwidth of up to several GHz) the decoupling cap supplies all the energy because the inductance to the regulator is humongous. Switching regulators usually have a bandwidth of a few MHz.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
