Author Topic: Is there someting to improve in this design? - Milliohm meter  (Read 3998 times)
Offline Arek_RTopic starter
  • Polish guy living in the UK
« on: November 10, 2018, 10:33:20 pm »
Hi I'm making Milliohm meter basend on the design from "Scullcom Hobby Electronics" youtube channel:
And I was thinking if there's something that I could do better on my schematic, any suggestions?
« Last Edit: November 11, 2018, 11:19:23 am by Arek_R »
Offline spec
  • MALE
Re: Is there someting to improve in this design? - Milliohm meter
« Reply #1 on: November 11, 2018, 04:23:53 pm »
+  Arek_R
Hell, that is a nice piece of engineering: very professional.  :)
Attached is another approach, which I have had on the back burner for a while. Thought you may be interested. The schematic is hot off the drawing board, and has not been prototyped or tested, so it may have some errors, but it's the principle that I am trying to convey.
« Last Edit: November 12, 2018, 03:25:59 am by spec »
« Reply #2 on: November 11, 2018, 04:36:32 pm »
Thanks :D
That looks like a EEVblog electronic load xD
It's a good idea as well, but I will stick to my concept as I have all the parts and I like it, was just asking maybe swap one or two components and add something there and there.
Offline spec
  • MALE
« Reply #3 on: November 11, 2018, 04:47:23 pm »
Let us know how it goes.  :)
Offline Gyro
« Reply #4 on: November 11, 2018, 07:53:24 pm »
Here's a Maxim app note (AN106) that shows a possible alternative current source. Deriving the test current from a 1.5V cell would offer a longer life than step-down from a 9V battery. Ref, opamp and mosfet can of course be substituted.
http://www.wentztech.com/radio/resources/Projects/AN106.pdf
Best Regards, Chris
The following users thanked this post: spec
Offline mvs
« Reply #5 on: November 11, 2018, 08:12:18 pm »
ADS1115 has pretty good PGA (differential input, zero drift, low gain error). How about throwing away ina106 and max680?
The following users thanked this post: Arek_R
« Reply #6 on: November 11, 2018, 09:24:25 pm »
Hmm, I never was thinking about using ADS' internal amplifier, didn't think it would do any good, will put everything on a breadboard and will compare both concepts, but for that I will have to wait for so8 adapter from ebay.
So I use maximum gain of x16(+/-0.256V)?
What about input protection, some schottky diodes maybe?
Offline mvs
« Reply #7 on: November 11, 2018, 10:10:10 pm »
With PGA you can implement ranges and switch gain on the fly. Current source will probably go up to 2V, so you can also use 2.048V range.
Input multiplexer has already clamping diodes (10mA).
PS On schematic you have 4.096V version of LT1634, it should be 1.25V.
« Last Edit: November 11, 2018, 10:18:05 pm by mvs »
Online MasterT
« Reply #8 on: November 11, 2018, 10:32:43 pm »
In the original design they use panel meter, basically voltmeter they can't adjust, so all this precision 100 mA bla-bla, 4+ resistors in parallel  makes sense. As you introduce uCPU into design, current doesn't have to be precise 100 mA anymore, and can be equal to any reasonable value 10 - 200 mA. Doing re-calibration on start-up by software would allow to correct all nuances.
« Reply #9 on: November 11, 2018, 10:44:31 pm »
Thanks!
Oh yeah that should be 1.25V version, sorry eagle doesn't have much when it's about such a unusual components, very often I end up using different component just with the same footprint/symbol...
...As you introduce uCPU into design, current doesn't have to be precise 100 mA anymore, and can be equal to any reasonable value 10 - 200 mA. Doing re-calibration on start-up by software would allow to correct all nuances.
So throw away current adjustment 100R pot and do it in software?
That's a good idea, thanks.
But because I'm a complete ultra noob in programming, I'm not sure If I will be able to implement all these great functions, was planning on using couple example arduino codes glued together with wet paper xD
« Last Edit: November 11, 2018, 10:47:08 pm by Arek_R »
Online MasterT
« Reply #10 on: November 11, 2018, 10:54:55 pm »
It's more than kick-off one pot. What I'm trying to say, design concept shown in the video was good in the past century, in 80-th & 90-th.  Precise reference, precise current source, same with voltmeter. It cost a lot. Having uCPU, you don't need all this analog precision, as song as it's not drift much in the minutes time frame. Using only one precise resistor in the circuits and doing comparative measurements by dual channel ADC, ads1115 , ads1232 etc, you can greatly reduce the cost of this project.
« Reply #11 on: November 11, 2018, 11:00:12 pm »
Yes yes one resistor, that's what I mean :p
What do you mean by "comparative measurements" ?
Online MasterT
« Reply #12 on: November 12, 2018, 02:12:09 am »
This picture explains:
https://www.quora.com/How-can-we-measure-the-value-of-resistance-with-CRO
Measure V and Vm using dual channel adc resistance can be calculated w/o knowing a current, since it zeroed out  of equation.
The following users thanked this post: spec, Arek_R
Offline spec
  • MALE
« Reply #13 on: November 12, 2018, 03:17:59 am »
What a brilliant approach- thanks for posting :)
Offline David Hess
  • DavidH
« Reply #14 on: November 12, 2018, 10:07:11 pm »
It would be a major design change but I would chop the excitation and synchronously demodulate to remove thermocouple errors.  Essentially this means reversing the test current between positive and negative and doing the same on the sense leads.  Otherwise it is not possible to take advantage of the accuracy (low drift) of even modern bipolar precision amplifiers never mind chopper stabilized amplifiers.
This is commonly done in high end multimeters which provide milliohm resistance measurement.
« Reply #15 on: November 12, 2018, 10:37:40 pm »
And how do you switch the current without any losses and stability issues of switching components?
It can't be just a H bridge out of N channel mosfets right? xD
Offline bson
« Reply #16 on: November 12, 2018, 11:23:30 pm »
Get rid of the pot - it's better to calibrate and correct the measurements before readout since you have a µC.  No need for anything adjustable.
Offline David Hess
  • DavidH
« Reply #17 on: November 13, 2018, 12:28:34 am »
Since it is a current being switched, the only losses in switching are limited to bias current errors which are trivial (or nonexistent if the design is clever)  and voltage drops which are irrelevant.  An h-bridge made out of MOSFETs could be used successfully although that might not be my first choice.
« Reply #18 on: November 16, 2018, 11:43:53 pm »
Actually you're right, 4-20mA exists for a reason :p
So what would be a better way to switch it if not h-bridge?
Offline unitedatoms
« Reply #19 on: November 18, 2018, 02:08:00 am »
may be add button for "set zero" routine. and may be 1 more button for good known cal standard ( say some independently measured specimen in range of 10 milliohm). i dont know what is this cpu board includes, i assume it has led and lcd.
also a jumper for firmware to choose between 60 hz vs 50 Hz if you decide to measure with immunity to mains background in integer amount of cycles during acquisition and averaging
Interested in all design related projects no matter how simple, or complicated, slow going or fast, failures or successes
« Reply #20 on: November 18, 2018, 11:26:30 pm »
Well its arduino pro micro(mega32u4) + 1'3 OLED graphic display.
But I also may use graphical "8x2" oled display instead.
And now with the amount of functions I may add a 4 membrane buttons, plenty of them on ebay for dirt cheap.
50/60Hz rejection haha, this primarly weekend project turns into quite advanced device xD
Not much time recently tho :/
Offline David Hess
  • DavidH
« Reply #21 on: November 21, 2018, 06:09:08 pm »
Diodes can be used for current switching with the advantage of lower capacitance and lower leakage.  But an h-bridge is easier to understand and likely good enough.
Offline Lukas
    • carrotIndustries.net
« Reply #22 on: November 21, 2018, 09:16:18 pm »
Seems like you're all missing one trick: Instead of using a DC current, use AC current and all offset errors are gone. See https://www.analog.com/media/en/technical-documentation/application-notes/an98f.pdf page 10 for an example. Instead of using a synchronous demodulator, digitizing the signal using the MCUs builtin ADC might also be feasible.
Offline kripton2035
