That's impossible to answer unless you define "reliable". How many hours without failure? Under what load? Which environmental conditions?
Generally speaking Meanwell is a decent brand making good quality supplies (even you picked the original supply from them). Ah, the replacement isn't Meanwell.
UL certification means that someone has actually checked the supply for safety issues, you should be able to find the test results online on the UL's website. That doesn't say much about the reliability of the supply, though, only that it likely won't kill you or set your house on fire. However, the datasheet doesn't say this was actually certified - only that it complies with requirements and that any UL/CE certification is up to the customer. Which isn't quite the same thing.
The typical circuit in the datasheet is just a bog standard fuse + mains filter arrangement required to comply with safety and EMC regulations.
