Author Topic: Voltage supply circuit with current sinking capability  (Read 1867 times)
Offline DanioIOTopic starter
« on: December 02, 2014, 06:49:05 am »
How can i make a LDO voltage power supply, which can also work as constant current sink if the connected device voltage exceeds the power supply output?
Offline void_error
  • I can transistor...
Re: Voltage supply circuit with current sinking capability
« Reply #1 on: December 02, 2014, 01:44:12 pm »
If you provide more details (input voltage, output voltage, output current) I might be able to give you a solution.
Trust me, I'm NOT an engineer.
« Reply #2 on: December 02, 2014, 04:20:36 pm »
I need something working from 30V and the output voltage should be min. 15V, output current isnt very important i will be happy with 1A.
Online Zero999
  • 0999
« Reply #3 on: December 02, 2014, 08:54:28 pm »
Then it's relatively simple. You need a voltage reference connected to a push-pull amplifier.
Offline macboy
« Reply #4 on: December 02, 2014, 09:04:15 pm »
More explicitly, look at using a power op-amp such as LM1875 (3875 for more power), amplifying a voltage reference like TL431. You don't need symmetric supplies for the op-amp, -5V is enough for the negative supply, our use single supply (neg supply is ground) if the output never needs to go below about 5V.
