Author Topic: Ground to inductor to ground capactior mystery  (Read 544 times)
Offline sausageTopic starter
« on: January 25, 2021, 01:38:56 am »
Hi all.
I'm currently troubleshooting a dead Commodore 64C and I found what I thought was a short across C56 which is a ceramic type capacitor. I took the part out and it was fine. Then I looked at the schematic and discovered this:
The point of interest is highlighted in blue. The Power Input comes from an external transformer. Pins 1, 2 and 3 on that plug are ground.
The mystery for me is this: The incoming grounding path goes through an inductor to the PCB ground. Before the inductor is one side of the capacitor. Essentially both sides of the capacitor will appear as a short, or at least plus the resistance of the inductor.
I'd be interested to know what this technique is for, and what it might be called so I can read up on it.
« Last Edit: January 25, 2021, 01:47:42 am by sausage »
Would love to meet up with people in the Canberra/Queanbeyan region who are keen to learn together.
Offline M0HZH
    • QRPblog
Re: Ground to inductor to ground capactior myster.
« Reply #1 on: January 25, 2021, 01:55:19 am »
L1 seems to be a common mode choke; the DC return will minimize core flux in L1.
C56 will mostly have an effect at high frequencies (transients?).
Offline retrolefty
Re: Ground to inductor to ground capactior mystery
« Reply #2 on: January 25, 2021, 01:57:01 am »
Looks like a high-pass filter (cap/inductor) on the ground line. Helps to filter out noise.
« Reply #3 on: January 25, 2021, 02:27:04 am »
Thank you muchly to you both.
