Author Topic: Is this routing bad/messy?  (Read 9661 times)
Offline aaronhanceTopic starter
  • Damit
    • aaronhance.me
« on: December 16, 2015, 06:27:54 pm »
Hello! I'm looking  to get some feedback on a little bit of routing/layout of the 4 layer board I'm making. The usb data lines are matched to about 0.1mm, from what I've read this is ok. I have ground planes around and under the crystal, and the caps are near to the mcu. Is there anything here that needs correcting or improving?
Thanks!
Offline stmdude
Re: Is this routing bad/messy?
« Reply #1 on: December 16, 2015, 08:12:09 pm »
Well, I'm not an expert, but I've built more than a few functioning boards..
The crystal routing looks good, a bit overkill, but it would certainly work.
Usually, just a trace that's tied to ground around the crystal is enough, hence the name "guard ring".
Oh, and if you're running out of PCB space later on, have a look at FA-238 (3.2mm x 2.5mm) sized ones.
Without knowing what MCU you're routing for, the decoupling looks a bit odd. Usually, you do a trace from the MCU into the power-rail, and place the cap as close to that pin as possible/convenient. The other pad of the capacitor goes the shortest route possible to ground. Usually just a via down to a ground-plane.
The ground-pins of the MCUs are treated the same way. Shortest way to ground, which is usually a via.
Also, all traces seem to be the same width. You seem to have a distribution-tree going on already, which is good. I usually beef up the trace that is the "trunk" of the tree, as to reduce voltage-drops and voltage-differences on the different VDD pins of the MCU itself.
Now, if you have a power-layer going on, just ignore what I just rambled on about. :)
Oh, and yea, 0.1mm matching of the USB lines should be fine. Just double-check the datasheet for your MCU so that you don't need in-series resistors for it. If it's USB host, you might also need a pull-up for the D+ line.
  • Damit
    • aaronhance.me
« Reply #2 on: December 16, 2015, 08:55:19 pm »
Thanks for the tips, I've changed it to a power plane under the mcu and will re-arrange the caps.
Offline mariush
« Reply #3 on: December 16, 2015, 09:15:09 pm »
The crystal footprint is huge compared to the mcu and other parts... have a look at digikey or other shops, they have smd crystals with built in capacitors and in much smaller footprints and with very reasonable prices.
Other comments,,, the picture is really to "suck" to give some meaningful advice... looks like an IC with huge amount of pins for the small size, with HUGE capacitors and resistors compared to the IC size and the USB connector footprint.. something doesn't seem right to me.  The traces are also looking bad, with 90 degree angles and all those vias under the IC etc etc..
Offline stmdude
« Reply #4 on: December 16, 2015, 09:22:25 pm »
Just noticed something..
The crystall has a rectangular thing around its footprint, and the traces to it and its capacitors are intersecting it. Is that on the copper-plane?  If so, then it won't work.
  • Damit
    • aaronhance.me
« Reply #5 on: December 16, 2015, 09:31:54 pm »
Thanks for pointing it out I think it may be copper, I guess I messed up when making the footprint and used that instead of a white line, partially due to eagles fantastic tool names.
EDIT: this is what I've got now:
Offline stmdude
« Reply #6 on: December 16, 2015, 09:41:14 pm »
So, which mcu is this?
It would help if I could read its datasheet to see what the decoupling is supposed to be like.
Also, why 4-layer? I can't see anything on the board that would warrant it.
  • Damit
    • aaronhance.me
« Reply #7 on: December 16, 2015, 10:03:16 pm »
here's the datasheet:
http://www.farnell.com/datasheets/1506142.pdf
It's a PIC32MX575F256L-80I
Offline Neilm
« Reply #8 on: December 16, 2015, 10:03:55 pm »
When doing decoupling, the trace should go from the via, to the capacitor then on to the processor pin. This will ensure that the capacitor is the source of energy for the current spikes rather than the power plane thereby reducing the noise on the power plane.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
  • Damit
    • aaronhance.me
« Reply #9 on: December 16, 2015, 10:10:20 pm »
Thanks for the tip!
Offline john_p_wi
« Reply #10 on: December 16, 2015, 10:21:04 pm »
You could really tighten things up, additionally I would suggest having the decoupling caps parallel to the processor, to have the traces as short as possible between the pins.  This app note is from atmel, but demonstrates similar methods:
http://www.atmel.com/images/atmel-2521-avr-hardware-design-considerations_applicationnote_avr042.pdf
Additionally, search for app notes for the processor family that you are using, there should be a wealth of knowledge contained in them.
« Last Edit: December 16, 2015, 10:23:15 pm by john_p_wi »
  • Damit
    • aaronhance.me
« Reply #11 on: December 16, 2015, 10:35:03 pm »
It's 4-layer because I have that fine pin pitch mcu and I also have 2x 48 pin devices, I figure 4 layer would be easier, besides 100x100 4-layer is the same price as 200x100 2-layer from the manufacturer I'm going with($75 for 5 boards).
Offline Gurpreet
« Reply #12 on: December 16, 2015, 10:42:33 pm »
From which manufacturer are you getting the boards made from?
  • Damit
    • aaronhance.me
« Reply #13 on: December 16, 2015, 10:47:15 pm »
pcbway
Offline robotix3
« Reply #14 on: December 16, 2015, 11:30:43 pm »
A good way for beginners to learn, I have found, is to look at reputable open-source boards and analyze what the designer is doing. Sparkfun.com has all of their in-house boards downloadable in Eagle format, I would check these out. Compare the PCB layout to the schematics. Look at trace widths, trace groupings, copper pours, via placements, etc.
Offline stmdude
« Reply #15 on: December 17, 2015, 07:50:47 am »
Alright, skimmed the datasheet, and came up with how I would have done it.
All signals are on the top layer. The bottom layer (only two layers) is just a massive ground-plane.
PCB Editor view:
3D Front:
3D Back:
The two-pin header next to the USB connector is where "VDD" comes from, as I had no idea how you were getting your VDD.
Without knowing exactly what you want to do, I'd still venture to guess that two layers would be plenty for your design. TQFP-64 with 0.5mm pitch isn't really fine-pitch these days with manufactured PCBs and decent tools. Neither would some 48-pin packages change that.  I've never had to go 4-layer yet, and I regularly do designs with multiple 100+ pin components with <=0.5mm pitch. And, as I mentioned, I'm not an expert.
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
« Reply #16 on: December 17, 2015, 08:45:19 am »
Bottom right, there's a trace  that goes across the copper relief of the component hole. That may be an issue.
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
Offline alexanderbrevig
  • Country: no
  • Musician, developer and EE hobbyist
    • alexanderbrevig.com
« Reply #17 on: December 17, 2015, 08:58:55 am »
Pretty sure you've made some mistakes on those decoupling caps though  ;)
Offline stmdude
« Reply #18 on: December 17, 2015, 10:23:37 am »
Might have, but if you see something I've missed, let me know, and I'll update it.
I just noticed that I didn't re-do the copper-pour, so the 2-pin connector effectively shorts GND and VDD, which would be an issue if you actually tried to power this board up. Doesn't change the routing though
  • Country: no
« Reply #19 on: December 17, 2015, 10:43:54 am »
Right now nothing would be powered.
Offline HackedFridgeMagnet
« Reply #20 on: December 17, 2015, 10:46:49 am »
Putting the IC at 45 degrees can help with fine pitch stuff. Looks pro too.
Offline stmdude
« Reply #21 on: December 17, 2015, 11:04:42 am »
Gawdammit..   That'll teach me to route before my morning coffee..   Jeez.   :palm:
Offline stmdude
« Reply #22 on: December 17, 2015, 11:14:37 am »
Ok, take 2.  Now, after my coffee
Offline ElektroQuark
    • ElektroQuark
« Reply #23 on: December 17, 2015, 11:44:02 am »
You may need a parallel resistor of about 1M with the crystal. Not always necesary but if it refuses to start working take a look at it.
Offline v8dave
  • Country: id
« Reply #24 on: December 17, 2015, 12:49:25 pm »
Don't have any 90 degree track bends. Use 45. I also see a few lines that are not at 45. Mostly aesthetics but it can make routing around them easier too so try to stick to horizontal, vertical and 45.
Beef up the power rails even if just short. Use the technique someone posted for connecting the decoupling caps to the micro power pins. Power issues are the biggest cause of failure in processor designs. :)
Use smaller via's for your signal lines. This will make routing easier too.
