Author Topic: Aoyue 2703+ problems  (Read 1061 times)
Offline light767Topic starter
« on: October 12, 2020, 08:48:29 pm »
Hi There
I have just brought and Aoyue 2703+ and while I wasn't expecting to have bought a top high end brand I'm still pretty disappointed with it.
I have just tried the solder iron and the hot airjet. I have set the solder iron at 380°C and it can merely melt the common SN60Pb40 alloy which should melt at much lower temperature. The hot airgun jet has no jet power at all, very very very low.
Do you have any suggestion?
« Last Edit: October 17, 2020, 01:55:36 pm by light767 »
Online wraper
  • Country: lv
Re: Aoyue 2703+ problems
« Reply #1 on: October 12, 2020, 08:59:21 pm »
It's a very old overpriced model. Soldering iron will perform better if you use larger tips and or tips of better quality. It has diaphragm pump which while having low airflow also knocks off components relatively easily due to it's pulsed airflow instead of continuous flow. Fume extractor is a useless trash. Not only it obstructs soldering and significantly cools down soldering iron tip, it simply passes air through itself without any filtering and blows it out of the hot air gun  :palm:.
Get rid of this junk. And don't buy anything from Aoyue since you can buy the same or similar low quality equipment 2-3 times cheaper from other Chinese brands.
« Reply #2 on: October 12, 2020, 09:27:43 pm »
So there are any 4in1 chinese station better than this one?
Online wraper
  • Country: lv
« Reply #3 on: October 12, 2020, 09:44:43 pm »
4 in 1, sucks at all functions. Get them separate, or at least 2 in 1. Not to say fume extractor of this form factor will suck no matter what. So forget about it.
« Reply #4 on: October 12, 2020, 09:46:55 pm »
is there a way to mod the station to improve it? I don't know ..changing the pump? Or the heating element of the solder iron?
Online wraper
  • Country: lv
« Reply #5 on: October 12, 2020, 10:01:30 pm »
Well, you could use better cartridges for soldering iron, for example genuine Hakko. If you did not try using soldering iron without fume extractor, try it. Probably it will make it acceptable as is. As of the rest, nothing much you can do with that unless you want to almost make another station from ground up.
« Reply #6 on: October 13, 2020, 05:44:57 am »
Stations like Yihua 992da are the same as mine?
Basically i had decided to buy this aoyue station because i have paid it 120 euro, it was an offer, so isn't much but i have to say that I'm disappointed anyway. Maybe I'll see if i can return it back.
« Last Edit: October 13, 2020, 07:01:44 am by light767 »
« Reply #7 on: October 13, 2020, 06:49:11 pm »
Any help?
« Reply #8 on: October 15, 2020, 08:37:44 pm »
I will return the Aoyue station to the seller.
If there is any alternative station to this one I will be interested. I have seen the Hakko 4in 1 that cost something like 4000 euro which is a monster price for me. Is there somethind decent not super professional as my use is not intensive.
Online wraper
  • Country: lv
« Reply #9 on: October 15, 2020, 09:29:36 pm »
You could buy this https://eleshop.eu/quick-706w-two-in-one-station.html There is no desoldering tool though. But hot air is way way better. Also it's build from quality components and build quality is also much better. Unless you need to desolder something in large quantities, I would simply buy inexpensive manual solder sucker.
Online wraper
  • Country: lv
« Reply #10 on: October 15, 2020, 09:32:40 pm »
That 4 in 1 has 2 soldering irons. There is no trashy fume extractor.
