Author Topic: protection diode  (Read 1196 times)
Offline glinjikTopic starter
protection diode
« on: February 19, 2022, 08:02:54 am »
hi can someone tell me an alternative for this protection diode please
All the truth in the world adds up to one big lie (Bob Dylan)
Online mariush
Re: protection diode
« Reply #1 on: February 19, 2022, 08:41:17 am »
1n5401  - max 100v voltage, 3A diode.    Forward Voltage is most likely irrelevant (it's big)
You can use higher voltage rating, you can use higher current rating, you can probably use slightly less current rating but I'm not sure because I don't know the rest of the circuit ....(or you could parallel 3 1A diodes to get a 3A diode, sort of)
So some options  (sorted by amount in stock, not by price, but lots of generic cheap diodes there) : https://www.digikey.com/short/zn1zwq9p
The following users thanked this post: glinjik
Offline bob91343
« Reply #2 on: February 19, 2022, 08:19:07 pm »
1N4007 might do.
Offline fourfathom
« Reply #3 on: February 19, 2022, 08:41:12 pm »
1N4007 is 1000V, 1A.  Probably not a good replacement for a 3A diode.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
The following users thanked this post: MK14
Offline bob91343
« Reply #4 on: February 19, 2022, 10:01:10 pm »
Maybe not, but still would do the job.  The 3A rating is somewhat arbitrary.  For nearly all its useful life, the diode will very likely never conduct.
Offline MK14
« Reply #5 on: February 19, 2022, 10:04:07 pm »
I don't want to be rude. But at the moment, we have very little idea as to the overall circuit, and what it does. Maybe it conducts nearly 3 Amps, nearly all the time, through that diode. The OP doesn't seem to have provided extra details.
So you can't say a 1 Amp diode will be ok, probably.
« Last Edit: February 19, 2022, 10:06:19 pm by MK14 »
Offline fourfathom
« Reply #6 on: February 19, 2022, 11:46:23 pm »
I could be wrong, but I assume that this is part of a power supply or regulator circuit and the diode is there to protect the pass transistor should the input be shorted while the output filter capacitor is still charged. (reverse breakdown voltage).  This diode will seldom if ever see any current, but in this fault condition it could pass many amps -- depends on the short, and on the capacitor.
Offline floobydust
« Reply #7 on: February 20, 2022, 02:42:25 am »
Note the diode doesn't actually give full protection- in the case the transistor has voltage at its emitter
you can still get backfeed across the E-B junction and damage the base-drive circuit.
An example of this is a DC power supply charging 12V battery.
If mains is turned off, there is still 12V at the emitter and the transistor backfeeds with ~7V avalanche to the drive circuit, which usually causes damage. OP's diode will just keep the filter capacitor charged.
Offline fourfathom
« Reply #8 on: February 20, 2022, 03:06:54 am »
No doubt there are still fault current paths, but when the input is grounded the diode in the OP's circuit will discharge the cap on the transistor emitter, so I don't see where the emitter voltage comes from to drive the E-B current.  If there is charge on the base circuit there could be B-E and B-C current, but the base circuit is usually at a high enough impedance to limit the base current.  But I'm imagining the rest of the circuit, so I could be wrong.
Which filter capacitor?  The invisible one on the transistor collector?  Yes it will, but the discharging cap I'm talking about is the invisible one attached to the emitter.  I guess there ought to be a series diode at the output of your battery charger.
Anyway, back to the OP's question:  It's better to match or exceed the current rating of the original diode -- it was probably selected for a reason.
