Author Topic: NEED Chip for halfbridge - variable frequency, variable duty cycle  (Read 1051 times)
Offline MacIntoshCZTopic starter
  • Country: cz
Hello everyone,
I have tesla coil with 17k turns with resonance frequncy about 3khz.
I would like to know which chip i should use  instead of ir2153 in schematic.
IR2153 would be deadly. 50% on 3khz. I might see some fotons in visible spectrum =).
http://danyk.cz/sstc4.png
author: danyk666 / diodegonewild
* I will modify schematic for chip. No need to worry about pins connection etc
Thanks everyone for help.
« Last Edit: August 08, 2020, 02:38:25 pm by MacIntoshCZ »
  • Country: cz
Re: NEED Chip for halfbridge - variable frequency, variable duty cycle
« Reply #1 on: August 09, 2020, 08:02:02 am »
No one knows?
I am searching but i just cant find any. I dont want variable duty cycle through feedback on load.
Hm maybe tl494 could do that job
« Last Edit: August 09, 2020, 08:08:31 am by MacIntoshCZ »
Offline elmascapoeira
  • Country: ar
« Reply #2 on: February 20, 2022, 06:28:34 pm »
i know its a bit late but anyway, of you connect to ground the pin3 of the ir2153 it power off the output, so you can try connect pin3 with a ne555 and thus reducing the duty cicle with it, but how the hell you have a coil with 17thousands of turns? it will dont work, you need about 800-1600 turns
« Last Edit: February 20, 2022, 06:30:52 pm by elmascapoeira »
