Author Topic: Why multiple capacitors in parallel?  (Read 2210 times)
Offline madhu.wesly01Topic starter
  • Country: in
  • If you want to be happy, BE!
« on: July 02, 2018, 04:27:14 am »
Wondering why you would choose to use smaller capacitors in parallel vs one bigger one. Can I use a single 47uF capacitor at the output, or I have to place 4 X 10uF capacitors as given in datasheet?? Will there be any difference??
Could you also let me know in general how to decide on capacitor package(size) used at input and output of the regulator ??
Thanks in advance.
Offline EEVblog
Re: Why multiple capacitors in parallel?
« Reply #1 on: July 02, 2018, 04:35:23 am »
The following users thanked this post: larsdenmark, queennikki1972
Offline EEVblog
« Reply #2 on: July 02, 2018, 04:37:02 am »
Basically just follow the datsheet advice. They often have entire sections devoted to choosing a bypass capacitors.
Offline b_force
    • One World Concepts
« Reply #3 on: July 02, 2018, 08:18:33 am »
Besides ESR it can also be cheaper or sometimes just fits better on the PCB when there are size limitations.
A 100uF is a lot smaller (height) than a 470uF.
In a lot of cases it's also easier to fit four smaller sized caps on a PCB than one big one (that will screw up your layout)
Offline Karlo_Moharic
  • Country: hr
« Reply #4 on: July 02, 2018, 09:43:16 am »
Redundancy
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #5 on: July 02, 2018, 09:50:29 am »
Redundancy
Not really. They tend to fail short. So adding more caps essentially increases the likeliness the entire unit fails.
