I bought an isolation transformer and prepared it for my need.
Now it has Live, Neutral and Ground pins connected to primary side of the transformer.
Live and Neutral pins to secondary side.( No Ground on secondary)
Is that correct ?
Now I want to measure ,with a oscilloscope ,on live side of a power supply( SMPS) adaptor.
So, I connect that tested power supply adaptor to a secondary side of the isolation transformer.
But must I also connect the scope to the secondary side of the isolation transformer or I not?
May I connect the scope to a common wall outlet?
