Well, it turns out that I was wrong about prices. Eleshop.eu has the MicSig probes cheaper than I thought.
I'm leaning towards DP750-100 since it has the most CMRR. 600V CAT II seems to be good enough. However output voltage is the lowest at 1.5V. But I have seen reports about it working with low voltage differential busses:
https://www.eevblog.com/forum/testgear/differential-probe-for-offline-pfcd-psu/msg4293502/#msg4293502https://www.eevblog.com/forum/testgear/micsig-dp10007-or-dp750-100-differential-probe/msg4378921/#msg4378921I'm sure there are better differential probes but €177+VAT is already in the upper range of what I'm willing to pay.
For isolation transformer, I'm thinking this one should be good enough to power that 300W ATX PSU, and probably other SMPSUs in the future, as long as they get just the load needed to regulate properly (I'm using a 10W 10R resistor right now).
https://www.tme.eu/en/details/pfs250_230_230v/safety-transformers/breve-tufvassons/Or perhaps this one, wich is somewhat cheaper and could be combined in the future with a variac into a case. Not sure about that. All AC things here are 220V unless they are tree-phase. Most probably I'll go ahead with just the isolation transformer and a 60W incandescent bulb in series (the only one I have been able to find). Any thoughts?
https://www.tme.eu/en/details/pvs250_230_230v/safety-transformers/breve-tufvassons/With this, I think the way recommended by Ian.M gets covered.
Now, should I follow bdunham7's recommendation, same isolation transformer. By the way, I got quite a few clues from your posts in that thread
Not sure about the probes, however. My GW Instek 1054B accepts 300V CAT 1 max input voltage IIRC and I assume this would be with 10x probes. It's said to be RMS voltage. So I guess this would be enough to work on the secondary side? Anyway I looked for the HV probes you recommended:
https://www.ebay.es/itm/332835001398.In the pictures you posted, I see various different probes at same time, i.e, a PP510, the linked High voltage one and still another that I can't identify, which seems to have an alligator adapter.
I see you are using the high voltage probe on the primary side and the PP510 on the secondary, but could you elaborate some more about the probes? One or two HV probes? 100x atenuation low voltage ones? Just 10 x attenuation would perhaps be enough on the secondary?
Last, the other way -getting an isolated scope (Owon VDS1022i)
https://eleshop.eu/owon-vds1022i-usb-oscilloscope.htmlI like this way because it would be the safest one for my benchtop scope, and being so portable I could use it for automotive work, I think. The specs seem to be good enough for most PSU work. Max input voltage is 400V, but p-p this time. Attenuation goes to 500x. Channel isolation would be 100:1 at 50 Hz and 40:1 at 10 MHz.
However I'm not sure if differential probes can be used, I looked for Testec TT-SI 7002 probes and I can see the warning "Only connect to a grounded measuring device!". Which wouldn't be the case with this isolated scope. Any comments about probes to use with this device?
