Author Topic: Datasheet for some eBay "generic" IR LED's ?  (Read 1668 times)
Offline onesixrightTopic starter
« on: October 16, 2017, 01:26:16 pm »
Hi All,
Anybody a clue what to use as a "basic" datasheet for some IR leds  from ebay? I bought a few:
- IR infrared LED 940nm Lamp High Power
- IR infrared LED 940nm Lamp Black Receiving
The seller wrote "generic" FWIW.  I tried to look for "940nm IR LED", but not a clue where to go ...  :-//
Thanks a bunch!
Offline Coceth
Re: Datasheet for some eBay "generic" IR LED's ?
« Reply #1 on: October 16, 2017, 03:15:37 pm »
That is one of the trade-offs of buying parts from eBay: no datasheet, no listed manufacturer, ultimately no responsibility. Maybe they are parts taken from the same factory that produces name-brand parts, but they can't advertise the exact origin, hence the killer price.
I bought a 50 pack of LEDs from eBay for $2 shipped, but I didn't expect, nor receive, a datasheet with a characteristic curve. For my little project, I didn't care, I just wanted cheap LEDs that got bright. Buying the same thing from Dig-key would have cost $10.
Offline rstofer
« Reply #2 on: October 16, 2017, 06:06:14 pm »
IR LEDs are a little harder to work with because the light isn't visible.  I can't simply change resistors until I get the amount of light I want.
Except...  I can look at the IR LED with a cell phone camera and get some idea about how it works.
Here's some data on a generic IR LED:  Vf=1.5V at 50 mA.  So, given a 5V power supply, calculate the series resistor as (5.0 - 1.5) / 0.05 or 70 Ohms.  Maybe start at 100 Ohms and work down.
https://www.sparkfun.com/products/9349
But that for THIS LED, not yours.  You will need to experiment.  Start at 5V 470 Ohms and work down until you see the knee in the graph when you finally get to Vf.  There's a discussion here but it includes superfluous detail at the semiconductor level:
http://www.phys.uconn.edu/~hamilton/phys258/N/led.pdf
The following users thanked this post: onesixright
Offline Twoflower
« Reply #3 on: October 16, 2017, 07:09:47 pm »
Careful with the camera approach. It might work well. But some cameras have very good IR-cut off filters included. For example the iPhone 4S main cam has a very effective filter. I killed 2 IR-LEDs before I actually checked how well the camera detects IR-light. Try with a IR remote control the capability to detect IR emission.
You could also try to slowly increase the voltage and detect the steep part of the current/voltage curve. That's probably the best operating point.
« Reply #4 on: October 17, 2017, 07:04:45 am »
Yeah I already noticed.  Same with my iPhone 6. However if you dim the lights and you look very (and I mean very) carefully, you can see a bit of purple-ish light being emitted. But, its very hard to see. Funny since some remotes being shown very well on the iPhone, different wavelengths?
Offline rstofer
« Reply #5 on: October 17, 2017, 04:43:48 pm »
Maybe try a DSLR camera?
Offline Twoflower
« Reply #6 on: October 17, 2017, 05:25:03 pm »
Yes, that different visibility might be wavelength related.
Just try the secondary, front facing cam. At least on my iP4S the IR visibility was much better.
« Reply #7 on: October 17, 2017, 07:14:55 pm »
Not much lucky with my Canon, but it works much better with my old Logitech 2Mp webcam  :-+
« Reply #8 on: October 17, 2017, 07:17:40 pm »
Good tip, just tested it!
On my iPhone 6, its much (and I mean much) brighter with the front face camera then the "better" rear camera... :-DD
