Author Topic: isolation v variac  (Read 447 times)
Offline Dave TurnerTopic starter
isolation v variac
« on: January 03, 2025, 02:50:21 pm »
Is there a reason why an autotransformer (Variac) should not come after a true isolation transformer?
Offline jwet
Re: isolation v variac
« Reply #1 on: January 03, 2025, 03:06:04 pm »
Its fine to do this and not unusual- its actually preferred in my experience.
Offline edavid
« Reply #2 on: January 03, 2025, 03:12:54 pm »
There are some bench products that are exactly that similar to that except wired the opposite way, such as B+K Precision 1655 and Sencore PR57 and PR570.
Very handy if you can find one at a reasonable price.
« Last Edit: January 03, 2025, 04:38:37 pm by edavid »
Offline bdunham7
« Reply #3 on: January 03, 2025, 03:52:34 pm »
Yes, the autotransformer has moving parts and exposed conductors so there is greater risk of accidentally rereferencing the output voltage to ground either by short or by leakage.  Although the energy will be limited, this still poses a potential shock hazard or DUT damage if you were relying on the output being isolated from ground.
There are some bench products that are exactly that, such as B+K Precision 1655 and Sencore PR57 and PR570.
The BK1655 and PR57, at least, are wired with the isolation transformer last, going more or less directly to the output sockets.  I haven't seen a PR570, but I'd presume they haven't changed the layout.
« Last Edit: January 03, 2025, 04:21:31 pm by bdunham7 »
The following users thanked this post: golden_labels
« Reply #4 on: January 12, 2025, 07:53:36 pm »
Thank you all for your responses.
Other than bdunham7's valid comment I haven't been able to find anything definitive, of course a commercial unit would/should have to include protection against zaps of that type.
I do seem to recall reading somewhere that there was a potential problem regarding impedance matching and power factor correction, though at low power consumption say max 300VA I doubt this would prove to be an issue.
« Last Edit: January 12, 2025, 07:56:39 pm by Dave Turner »
