Author Topic: Convert battery powered light to hardwired  (Read 649 times)
Offline glenfrickerTopic starter
« on: December 31, 2024, 05:33:06 pm »
Hello everyone.  I'm new here and in need of some advice.  I purchased a light for my dartboard and I'm tired of changing batteries.  The light has two compartments for 2 AA batteries.  With the correct adaptor, would I have to connect the adaptor to both ends of the compartments and if so how would I do this.  Please see the attached pictures for explanation.  I think this can be done but I am unsure how.
Thanks in advance
Offline Grandchuck
Re: Convert battery powered light to hardwired
« Reply #1 on: December 31, 2024, 05:50:41 pm »
Do you have a DMM?
« Reply #2 on: December 31, 2024, 06:06:57 pm »
Sorry for my ignorance, but what is a DMM?  Is that a multi meter?  If so yes I have one.
Offline Grandchuck
« Reply #3 on: December 31, 2024, 06:11:16 pm »
Yes.  Probe the battery ends until you measure about 6 volts.  That is where you will connect the adapter.  Be sure to observe polarity.
Online schmitt trigger
  • Country: mx
« Reply #4 on: December 31, 2024, 06:18:21 pm »
With your meter, you will have to figure out whether your batteries are in series or parallel.
I have a similar device. The 6 alkaline batteries should provide 9 volts, but in reality it is only 4.5 volts.
The 3 series connected top bank is in parallel with the 3 series connected bottom bank.
Please determine how yours is connected first.
Online BeBuLamar
« Reply #5 on: December 31, 2024, 06:47:36 pm »
There are lots of screws there I think you can take it apart and see how it's wired.
« Reply #6 on: December 31, 2024, 07:21:48 pm »
I found this on Amazon.  I think it will work.  Am I on the right track?
5Volt 2A DC Power Supply Adapter 5V Power Supply 10W AC Adapter 100V-240V AC to DC 5V 2A 1A Power Adapter Transformers Replacement Power Cord 5.5mm*2.5mm DC Plug
Offline Grandchuck
« Reply #7 on: December 31, 2024, 08:33:50 pm »
Ummm ... did you measure about 6 volts?
« Reply #8 on: December 31, 2024, 08:37:48 pm »
No I didn't.  I'm going by what was printed on the light itself.  Please see attached
Offline Grandchuck
« Reply #9 on: December 31, 2024, 08:51:24 pm »
If the plug is correct it should work.
« Reply #10 on: December 31, 2024, 09:27:50 pm »
Thanks for all the help!
Online tunk
  • Country: no
« Reply #11 on: December 31, 2024, 09:38:43 pm »
Check the polarity of the 5.5mm plug.
Your light uses center negative, AFAIK most plugs/adapters have center positive.
« Reply #12 on: January 01, 2025, 06:09:23 pm »
I think I found the correct one.
Accessory USA 5V 1A Mains DC Switching Adaptor Power Supply Negative Center 5.5mmx2.5mm PSU
Offline mariush
« Reply #13 on: January 01, 2025, 09:10:49 pm »
If you have a soldering iron available, you could just open it up , cut the traces and flip them around with a couple wires.
Just make sure to remove the batteries. They probably use the positive on the outside because the jack has an on/off mechanism inside that disconnects the batteries when a plug is inserted.
Or you know, you could just get a panel mounted barrel jack and drill into the case a hole and solder wires to the traces
2.1mm ID / 5.5mm OD : https://www.digikey.com/short/8t2rq425  - the standard for lower current adapters
2.5mm ID / 5.5mm OD : https://www.digikey.com/short/9tw8tb3t - more common in higher current adapters
« Reply #14 on: January 02, 2025, 06:39:19 pm »
Thank you for your help.  It already comes with the adapter port that is center negative.  I think I found an adapter that matches.  Will this one work?
Offline IanB
« Reply #15 on: January 02, 2025, 06:45:20 pm »
It seems like it should work. It has the right voltage, it is center negative, and it is the right size of plug.
« Reply #16 on: January 03, 2025, 04:50:58 pm »
Thank you for your help!
