Author Topic: isopropanol question  (Read 4048 times)
Offline digsys
    • DIGSYS
Re: isopropanol question
« Reply #25 on: June 30, 2019, 12:22:55 am »
Quote from: bob91343
I don't dispute the hazards of this solvent.  However, I have been using it for decades and am a relatively healthy 86 years old.  So maybe I will die from it but so far so good.
Yup, same :-) Still have heaps as well, and don't forget carbon tetrachloride - we'd wash our hands in it at high school !! Yup still alive :-) ahhhh memories
Offline bob91343
« Reply #26 on: June 30, 2019, 12:53:25 am »
Don't forget methyl ethyl ketone.  That was the solvent of choice for a few years.
The following users thanked this post: digsys
Offline Shock
« Reply #27 on: June 30, 2019, 01:19:44 am »
Great for dissolving plastics, pure Butanone not sure if I'd want to clean PCBs with that.
Offline bob91343
« Reply #28 on: June 30, 2019, 02:57:35 am »
Acetone is very powerful.  But young women use it a lot to remove nail polish.
Offline rcbuck
« Reply #29 on: June 30, 2019, 03:21:06 am »
I use a toothbrush and denatured alcohol for the first cleaning stage. I follow up with IPA and a different toothbrush. I then rinse under running cold tap water for about 30 seconds. I have high water pressure here, about 95 PSI. Then immediately dry the board with a hair brush dryer set to high temperature and high blow speed. The boards always end up looking very clean. No signs of damage to the silk screen or solder mask.
The following users thanked this post: Lucky-Luka
Online jmelson
« Reply #30 on: June 30, 2019, 04:06:30 am »
Hi all
I've read that isopropanol is a good choice to clean up the board after the soldering is done.
I've tried it with my second ever pcb.
The result wasn't satisfying at all.
After I brushed some 99.9% isopropanol on the back of the board a sticky white patina formed.
I've tried to clean the mess using a polishing cloth.
The result is in the picture.
I'm not satisfyied at all.
What's the problem?
Cheers
First, it depends on the flux used.  There is no-clean, solvent-clean and water soluble.  If you really need to clean the board, then use water soluble flux (WS) and just wash in water, maybe with a little gentle scrubbing with a toothbrush.
If you use one of the other fluxes, then it can be difficult.  There are flux remover preparations that have a variety of stuff to break down and hold the flux in suspension.  One was roughly equal parts of isopropyl, ethanol and ethyl acetate.
But, what I do for the non-WS flux is use plenty of alcohol, let it soak in for a minute, then brush with a toothbrush for about one minute, and immediately rinse with lots of water.  You will see the alcohol turn white when the water hits it, that is the flux residue dropping out of solution.  You need to wash it away as rapidly as you can, before it deposits back onto the board.  Depending on the required level of cleanliness, one or two cycles of this process should get the board pretty clean.
For ordinary digital boards, I use no-clean flux and don't clean the boards.  For critical stuff like high-impedance or high voltage circuits, I use either solvent clean or water soluble.
Jon
Offline Shock
« Reply #31 on: June 30, 2019, 04:30:33 am »
Plain tap water is not good for electronics, especially finishing with it. Denatured alcohol contains additives as well.
Instead I would dilute pure IPA with deionized water, or if you needed something more aggressive make either an IPA or deionized water solution along with some other electronics safe detergent or more aggressive solvent (this is what manufacturers do). Rinsing with deionized water or IPA (in a ventilated area) from a squirt bottle works well to wash it all off, you can always do a two step rinse.
« Last Edit: June 30, 2019, 04:36:45 am by Shock »
Offline vk6zgo
« Reply #32 on: June 30, 2019, 05:25:09 am »
You can get a bit too "precious" with cleaning PCBs, especially ones that have already been in service.
These often accumulate a layer of dust & other "gunk" over the years, but continue to operate properly.
As I now have to buy my own solvent, I have  gone to plain old "methylated spirits".
People say it leaves "a white residue", but in my experience, that is just dissoved flux that hasn't been wiped away properly.
Offline Brumby
« Reply #33 on: July 01, 2019, 04:00:05 am »
so what do you use? only a toothbrush?
If you scrub the board with alcohol and brush, then rinse it off with alcohol there should not be any residue, it will just dry clean, no wiping needed.
This is how I do it.  I have IPA in a spray bottle which makes for easy application.
