Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Issue Measuring Large Capacitors with Multimeter
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Issue Measuring Large Capacitors with Multimeter (Read 615 times)
clansd99
Contributor
Country:
on:
January 02, 2023, 08:58:33 pm »
Hi all,
I am having an issue measuring capacitors with my EEVBlog BM235 multimeter, which I've had for quite a few years. It does a bang on job measuring capacitance down around 100nF, but when attempting the same with 470uF and 2200uF electrolytics, the meter doesn't do much for a second or two and then the screen light starts flashing and the meter beeps incessently.
I've tried replacing the batteries with known good ones, but no luck. I haven't used this functionality much before, so perhaps I'm just missing a way to set the range? Overall I love this meter and it has served me well. Figured I should ask on here before contacting customer support
-Chris
Logged
Vincent
Regular Contributor
Country:
May or may not be a Tektronix fanboy
Re: Issue Measuring Large Capacitors with Multimeter
Reply #1 on:
January 02, 2023, 11:40:35 pm »
Larger electrolytics need a not unsignificant amount of charging for the multimeter to perform any kind of useful measurement.
While I don't have this specific model, I've measured a fairly large number of capacitors over the years with this thing:
The bigger the cap, the longer the meter takes to spit out a measurement. And 1 000uF seems to be the practical upper limit. I think I did manage to measure a larger capacitor at some point but it took like 30 seconds, it was ridiculous LOL.
I wouldn't be surprised if other multimeters with a capacitor function have a comparable limit in the lower 3-digit uF range.
Logged
BeBuLamar
Super Contributor
Country:
Reply #2 on:
January 03, 2023, 12:23:06 pm »
May be you can try to discharge the capacitor first. That is recommended in the manual. Other than that it should measure up to 10,000 Microfarads.
Logged
jonpaul
Super Contributor
Country:
Reply #3 on:
January 03, 2023, 12:30:39 pm »
Use RLC bridge, HP, Wayne Kerr, most have models with very high C.
But no need to measure the C, a bad cap will show visible leakage, sweliogn and test high for leakage at rated V.
Just a DC PS and ma meter are enough.
Jon
Logged
Jean-Paul the Internet Dinosaur
Kleinstein
Super Contributor
Country:
Reply #4 on:
January 03, 2023, 12:36:04 pm »
Discharging is needed and if used with a high voltage before it can take a longer/repeated discharge (e.g. a few minutes) because of the relatively high DA of electrolytic capacitors.
The measurement just takes time - this could be some 5 seconds, how much depends on the meter.
Logged
EPAIII
Super Contributor
Country:
Reply #5 on:
January 04, 2023, 09:22:48 am »
A suggestion:
https://www.amazon.com/Aideepen-Mega328-Transistor-Capacitance-Battery/dp/B01M0UXHYY/ref=sr_1_1_sspa?crid=1N2IFO0PQB356&keywords=electronic%2Bpart%2Btester&qid=1672823944&sprefix=electronic%2Bpart%2Btester%2Caps%2C4410&sr=8-1-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExU0JQUklGQ1RPTVVDJmVuY3J5cHRlZElkPUEwNzE5MDEwMUg3M0JOVllLMkJFMCZlbmNyeXB0ZWRBZElkPUEwODAwODUxQ1VPNEZTWEpPMTg3JndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1
They work amazingly well. Wish I had one in the 1960s.
Logged
Paul A. - SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
MrAl
Super Contributor
Reply #6 on:
January 04, 2023, 11:28:47 am »
Try to measure the DC voltage across the cap with another digital meter and see what the voltage is doing.
As others said, it may take longer to read the value with a larger capacitor.
I would think the meter would charge the cap at least a little because it is polarized. With non polarized caps you can test with pure AC.
If the cap has a high leakage then it may not test right. You might be able to test that with an Ohm Meter, or meter set to the Ohms scale.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
