A lamp, just like your picture shows!6W at 12V is 500mA, so try a car sidelight or indicator bulb...
A simple current mirror can be made with 3 parts: a transistor, a resistor, and a diode (or diode-connected transistor)The other obvious answer is of course just a 24 ohm resistor.
Quote from: Delta on May 16, 2016, 02:35:07 pmA lamp, just like your picture shows!6W at 12V is 500mA, so try a car sidelight or indicator bulb...Thanks for responding! I couldn't seem to find any lamps that are higher than 500mA. The best I could find was a 1W 12V LED.Quote from: klr5205 on May 16, 2016, 02:55:45 pmA simple current mirror can be made with 3 parts: a transistor, a resistor, and a diode (or diode-connected transistor)The other obvious answer is of course just a 24 ohm resistor.Thanks for the info! I'll have to study about current mirrors now, and I'm sure that'll be useful to me in the future. But I think the obvious answer of just using a resistor was what I was looking for. My mind wasn't working well because I'm tired of concentrating on circuits since yesterday.
Quote from: Jay112 on May 16, 2016, 03:02:38 pmQuote from: Delta on May 16, 2016, 02:35:07 pmA lamp, just like your picture shows!6W at 12V is 500mA, so try a car sidelight or indicator bulb...Thanks for responding! I couldn't seem to find any lamps that are higher than 500mA. The best I could find was a 1W 12V LED.Quote from: klr5205 on May 16, 2016, 02:55:45 pmA simple current mirror can be made with 3 parts: a transistor, a resistor, and a diode (or diode-connected transistor)The other obvious answer is of course just a 24 ohm resistor.Thanks for the info! I'll have to study about current mirrors now, and I'm sure that'll be useful to me in the future. But I think the obvious answer of just using a resistor was what I was looking for. My mind wasn't working well because I'm tired of concentrating on circuits since yesterday.Tail light/brake light bulb should be available at an auto supply store.5 each 1/2 Watt 100 Ohm resistors in parallel - 600 mA
