Author Topic: Issues with LTspice XVII Update  (Read 1327 times)
Offline ChanceMcCranceTopic starter
« on: September 01, 2018, 01:15:23 am »
When I opened LTspice XVII this afternoon, it said that it had been over a 100 days since I last had the software updated.  I chose the option to begin the update and this 25MB update has been going on for well over three hours.  It seems to have gotten stuck at 26% which is specifically the /PowerProducts/LTC3813.asy.gz file.
Has anyone else encountered this issue?  If so, where you able to find a way to get around it and complete the update?
Offline Microcheap
Re: Issues with LTspice XVII Update
« Reply #1 on: September 01, 2018, 02:05:28 am »
I think you must run LTspice as administrator in order to be able to update it. If it doesn't work, simply download a new installer:
http://www.analog.com/en/design-center/design-tools-and-calculators/ltspice-simulator.html
Offline iMo
  • Country: va
« Reply #2 on: December 19, 2018, 12:24:19 pm »
I've discovered today the latest LTSpice VII stops working when "EchoLink" application is installed.
Removing the EchoLink enables LTSpice again.
Tried on 2 machines, Win7 64bit..
