Author Topic: Issues with my first microscope  (Read 6685 times)
Offline Kfire778Topic starter
Re: Issues with my first microscope
« Reply #25 on: April 03, 2019, 10:30:59 pm »
OK I have some good news, an not so good news, a friend of mine had some eye pieces that were the same size as mine, except they were 10x/22, an these things are spot on.  He shook my left eye piece an something inside was bouncing up an down, not something I would have wanted to honestly do just because of how much csn go wrong, an how accident prone I am.  But right now I'm having absolutely no issues.
Offline jfiresto
« Reply #26 on: April 04, 2019, 08:30:47 am »
Good job. One of my first tests is to pick up a piece of optics and gently shake it to see if anything rattles. I do this over a large tub, if it is, say, an old microscope, in case something falls out. (It has happened.)
If I got things right, the worst case scenario is that you may have to buy some new and better eyepieces? Did you see any vignetting with the 10X/22 ones?
-John
Offline Psi
« Reply #27 on: April 04, 2019, 08:49:50 am »
You can get a new pair of WF10X/20 on aliexpress for $21 inc shipping.
Lots of people selling them.
This store looks to sell a few types, check it out
https://www.aliexpress.com/item/One-Pair-WF10X-WF15X-WF20X-WF25X-WF30X-Eyepiece-For-Stereo-Microscope-Wide-Field-20mm-15mm-10mm/32897739739.html
« Last Edit: April 04, 2019, 08:53:30 am by Psi »
Offline Nusa
« Reply #28 on: April 04, 2019, 09:57:07 am »
Sounds like you have a complaint for wherever you bought the microscope from. Defective eyepiece, which should be replaced.
Offline grizewald
  • Country: ua
« Reply #29 on: April 04, 2019, 04:05:23 pm »
Great to hear that you've found the cause of the problem!
  Lord of Sealand
Offline lordvader88
« Reply #30 on: April 04, 2019, 05:52:21 pm »
I got the Andostar  301, it doesn't have an eyepiece, but was a lot cheaper. Works great so far, expect I haven't figured out how to save files directly onto my PC. I might have to order a microSSD card and reader for it to get stuff onto PC, which is a pain.
Offline grizewald
  • Country: ua
« Reply #31 on: April 04, 2019, 07:32:39 pm »
I've tried soldering with a microscope camera and a screen. It's incredibly frustrating as you don't have any depth perception. The first time you look through a proper stereo microscope and experience the 3D view, you'll understand why it's the only option.
  Lord of Sealand
Offline jmelson
« Reply #32 on: April 05, 2019, 10:47:06 pm »
YUP!!!  Quite true, the stereo microscopes have two objectives that are pointed toward the place where the unit focuses, and some prisms to bend the image so it comes in more straight-on to your eyes.  So, you get two different images presented to look as a big thing a foot or two away from your face.  This reduces eye strain and just quickly becomes natural, and you develop a new 3D adaptation for what you are working on in micro-scale.  Between the mon-ocular view on a screen and maybe some delay between the real object and the screen, I can't imagine that would be great.
Jon
