I need to generate a table of component placements so an assembly company can assembly my boards.
The problem is knowing what exactly is "zero degrees" for each component. I found some documents and webpages (mainly this page and there's a link to another PDF on the bottom of that page)
http://blogs.mentor.com/tom-hausherr/blog/tag/ipc-standards/Now here's the confusion, I take out a piece of cut tape with diodes, holding it with cathode on the left and anode on the right (as dictated by IPC-7351 document), the tape will have holes on the left side. I take out another piece of cut tape with some SOT-23-5 chips, hold it so that the side with 2 pins is on the right (as dictated by IPC-7351 document again), the tape will have holes on the right side.
What the hell? Why is it different?
The real problem is I don't know how to orient a lot of custom components in my CAD library, and I am trying to depend on the tape to tell me what the zero-degree orientation should be. If there is a discrepency between a diode and SOT-23-X, then I don't know which convention to follow.
