Author Topic: Hooking up a TO82 Opamp  (Read 2763 times)
Offline AndreiTopic starter
« on: April 13, 2015, 12:18:30 am »
I am trying to hook up a TL082 opamp as a simple non inverting amplifier for the first time. The datasheet for the part is here: http://pdf1.alldatasheet.com/datasheet-pdf/view/173078/UTC/TL082.html
What I am essentially trying to breadboard is http://en.wikipedia.org/wiki/File:Operational_amplifier_noninverting.svg
For the two resistors, I chose them both to be 10K for a 2x closed loop gain. The Vcc- and  Vcc+ are -5V/5V respectively. The input signal is a sinusoidal waveform of 1Vpp at 1kHz. I expect a 2Vpp output, with some lag.
However, when I flip the switch on on the power supply, the output of the opamp dips to -500mv and stays there with no change. If I dial up or down Vcc+ and Vcc- the output voltage decreases/increases respectively
I checked ground to Vcc+ and it checks out at 5V and ground to Vcc- and it checks out to -5V. Vcc+ to Vcc- gives me about 600mV which seems odd?
Any ideas would be appreciated, I am certain I am doing something incredibly stupid. I verified the input and the output on the scope.
Thanks.
Offline mushroom
Re: Hooking up a TO82 Opamp
« Reply #1 on: April 13, 2015, 12:28:55 am »
It could be oscillating...
Here is an image of the output of an op amp (CA3130, single rail 0-5V supply, gain 1 buffer) without compensation capacitor :
« Reply #2 on: April 13, 2015, 12:34:35 am »
Hi mushroom,
I pulled it up on the scope as well, the output is not oscilating, it is set at a very stable constant -400mV.
Offline Andy Watson
« Reply #3 on: April 13, 2015, 01:11:37 am »
....  Vcc+ to Vcc- gives me about 600mV which seems odd?
More than odd! I go as far as to say Wrong :)
Either you haven't made a common ground between your power supplies, or you have a short circuit through a diode or other silicon junction.
Edit: Pictures, per chance ?
« Reply #4 on: April 13, 2015, 02:02:47 am »
Hey Andy,
As it turns out it was a bad lead to Vcc+. Measuring the resistance across that wire lead, it's 0.3M Ohms :S, changing the lead results in expected behaviour. Quite the stupid problem ...
Thanks for all the help!
