Author Topic: How Do I Solder This  (Read 556 times)
Offline cortesTopic starter
« on: September 03, 2022, 08:16:23 pm »
My first project was on a breadboard. This is my second one. The board shown below is part of a kit to mount an ATOM lite. Other than the ones next to the pins at the top, none of the through holes are connected. I want to wire ground and one of the GPIO pins to the connector. Do I solder the orange connector to the board and then solder wires on to same pins? It seems like a logical way to do it. I'm asking in case there's a best practice to do these types of connections.
Online ataradov
    • Personal site
Re: How Do I Solder This
« Reply #1 on: September 03, 2022, 08:36:45 pm »
Yes, this is a typical way of doing it. Solder all the connectors first, so they are mechanically held in place, then use wires to make electrical connections.
Alex
Online jpanhalt
« Reply #2 on: September 03, 2022, 09:15:20 pm »
Typical pin per hole.  Stuff two wires (e.g., 24 awg or thinner) in a single hole.
EDIT: Actually, with 0.1" pitch, 1206 and 1210 SDM's fit perfectly.
« Last Edit: September 03, 2022, 09:17:11 pm by jpanhalt »
