... depends on how clean I'm able to keep it.
..... and the truth comes out.
Did I say that out loud?
heheh.
Once you get over the "resistance to change" barrier, it is actually easier.
There is something valid with the world being smaller than olden times to use interchangeable systems, but that's the only value in metric that holds up to scrutiny.
The first thing that should have been a determining factor in picking useful units is simply: "What are the benefits of number systems under consideration?"
To assume that base 10 embodies some kind of obvious superiority is short-sighted. Yeah, OK, you can just move decimal points on paper. Hurrah.
We familiar with tech stuff accept that binary, octal, hex and decimal all have their place and benefits. The same is true for ancient systems. They didn't just drop out of the sky - they were useful for the people developing/using the system. First ask why those number systems evolved the way they did. And before you point to a goofy origin of any arbitrary unit (like "the king's foot" which is just a tired argument), keep in mind that metric units were also arbitrarily created. Even temperature, which seems to "make sense" to be based on freezing and boiling temperature of water at sea level, begs the question "Why water?" and maybe even "Why at sea level?" (I'm not saying that the choice doesn't make sense, just pointing out that it is still arbitrary at the root. Any unit of measure is going to be based on an arbitrary assumption - it just comes with the territory). Also, the units have been tweaked over time based on correcting for errors discovered due to improving technology/methods for measuring them.
This in particular baffles me. 1) Metric is based on arbitrary unit to begin with. 2) Universal agreement on unit of measure is useful. 3) so
change the units from time to time (?), which at minimum is a timing arbitrariness. Oh well. (Didn't this happen again
just recently??)
Anyway, "resistance to change" is a thing, but "skepticism about change" is also a thing. Rigid adherence to either isn't healthy, so I fall on the skeptic side since there seems to be plenty of rigid dogmatic compliance to the other. Even if the course doesn't change, the discussion is always useful IMO.
Moving on...
I've been pretty busy so not enough time to work on my shop. But I got this far a couple days ago. At least I can finally sit there and do something in a pinch.
Funny that before, my equipment was crowding me such that often I had no space to work and now it looks like I hardly own anything. Oh well. It's a flat spot so should fill up in short order. I'm still looking forward to getting my permanent shelving and organization installed. Those shelves are temporary and just hung so that I could do a little work as well as for helping to visualize what I can do from what I've got to work with.
