Author Topic: JFET approximations (gate-Voltage)  (Read 887 times)
Offline sspj9
« on: February 03, 2016, 06:17:51 pm »
I designed a JFET to output a constant current of 10mA for an assignment. Using 2N3819 with Vdd 20 V, we assumed that Vg is 4V, however we need to explain to why we set it to 4V. I mean we could set it to any value right and just change the resistors. Can anyone help?
Thanks.
« Last Edit: February 03, 2016, 06:29:50 pm by sspj9 »
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: JFET approximations (gate-Voltage)
« Reply #1 on: February 03, 2016, 06:52:42 pm »
Not sure, the other way of asking the question is explain why you chose the resistors, presumably you have cme up with a suitable compromise of resistors and Vgs
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline Gyro
« Reply #2 on: February 03, 2016, 07:21:20 pm »
This Vishay App note might be of some help to you:
http://www.vishay.com/docs/70596/70596.pdf
Chris
"Victor Meldrew, the Crimson Avenger!"
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: February 03, 2016, 10:42:40 pm »
2N3819 isn't a very good choice for this... in most cases, Vg would need to be forward biased.
Seven Transistor Labs, LLC
Offline alsetalokin4017
« Reply #4 on: February 03, 2016, 10:52:28 pm »
"...because it works...."    ?
No, I guess that answer might be ok in a physics class, but probably not in an engineering class.
