Author Topic: JFET as replacement for analog switch like DG444 and question about RDS(on)flat  (Read 5590 times)
Offline mfratus2001
The current domain is hard to maintain with accuracy, since all analog switches are going to be variable.
Instead, why don't you operate in the voltage domain for your selectors, and use a voltage-to-current conversion? That way the on-resistance is a minor factor.
I just can't see switching a 1-Ohm resistance in with any analog switch (even a big MOSFET) and having repeatability. Otherwise, use relays.
The following users thanked this post: julian1
Offline julian1
  • http://blog.julian1.io
A trans-impedance amplifier as Kleinstein mentioned? I had to wikipedia it - but was thinking about whether it would be possible to use a jfet input op-amp with an output diode (ideal rectifier) and shunt-valued resistor feedback (tia), and then use the non-inverting input (0V or -10V) to control which tia op-amp was active. But I'm not sure it can be done without some additional switching complexity.
Agreed.
And once there's one relay in the path - then iterating ranges will always be slowed down by the mechanical action of the relay. I'm still thinking it may be simplest (and economically equivalent to analog-switches) to just use relays for all ranges up to 10uA. 10uA being the minimal permissible current to ensure good relay contact connection according to the datasheets for Omron signal-relays.
Offline Kleinstein
The trans-impedance amplifier is attractive for low to very low currents. It gets more difficult for more than about 1 mA, as the OP has to drive the measured current and at a higher voltage drop self heating of the resistor might get a problem. The advantage is that in an TIA the drop on the resistor can be higher (like 1 V or even 10 V) this way offset errors of the OP are not that important and one can thus use low bias JFET of CMOS types. The main range to use an TIA is if you want to measure with better than pA resolution - so more like below 1 µA full scale.
For the large currents, the chain of shunts is the usual way, possibly using a fully separate shunt for very high currents. The usually higher bias current of low drift / offset OPs somewhat limits the use of the shunt scheme to very low currents. So ranges of less than about 10 µA might need a compromise on the OP.
I am a little confused with the resistor and current values used in the first circuit plan - usually the voltage at shunts is low - more like 20 mV - 400 mV. It is only in circuit more like an TIA that compensate for the drop, that a higher burden is more common. At high currents, self heating is strong argument for a low drop. What is the application ?
As the switch is not in the voltage reading path, the switches are not that critical with respect to on-resistance. So there is no big problem in also switching 10 A through MOSFETs (or JFETs if you are willing to spend the money) - it is leakage that might be a problem. So for leakage reasons a relay might be better here - still leakage of the protection circuit remains. As the switches are only for directing the current, they could even work for the very low currents below the 10 µA limit from the relay specs - we don't really care about a little higher drop that might occur at such low currents. However, FET switches are usually cheaper and lower power at such low currents.
Offline julian1
A current source. The resistors are part of the regulation loop, so burden voltage is not an issue. I was aiming for 1A max output - not 10A - but you're still correct about self-heating which I have somehow managed to overlook. The higher current ranges will need to use resistors with a lower voltage-drop and amplification rather than a buffer to align with other ranges.
I've seen schematics for older current sources with a 1G sense resistor switched by a relay (10nA range) where the relay is part of the measurement- using what I think is a Coto relay part. But I can't find any relays that match that kind of minimum permissible current.
I suspect that if one can periodically (eg. on instrument startup) push a higher current through the contacts then that would be sufficient to clean them of any oxides/debris.
Alternatively perhaps any added resistance - from the low current being outside spec - is simply dwarfed by the size of the G-ohm range shunt resistor.
« Last Edit: March 19, 2017, 11:29:39 am by julian1 »
Offline Kleinstein
For an active current source over-current protection is less of an issue and the possibly high drop is allowed if self heating is considered. It's also possible to have current in one direction only.  I am not sure about the very small currents - the power part might limit the useful range due to leakage too.
For operation with very low currents there were special mercury whetted relays, that work well and very reproducible, but are not available anymore for normal use. AFAIK a normal relay contact at very low current might give an extra voltage drop of a few µV. So it should not be a problem in the current path, but it might be a problem in the voltage path. Relays with gold contacts are already quite good - typical performance can also be much better than guaranteed.
For most of the ranges the series connection of the shunts should be fine. Otherwise one could use separate switching for the current (e.g. relay or MOSFET) and the voltage sensing (CMOS switch chip). It is much less trouble than having the switch resistance as part of the shunt, even if a cheap CD4052 or similar is used.
Offline julian1
If we organize for the higher current ranges - to use lower voltage-drops to limit self-heating (eg 1V rather than 10V). Then that makes controlling the n FET gates much simpler. eg. Just drive it +10V above GND, rather than +10V above a S that might be +-10V wrt GND.
I think that removes my hesitation about gate control complexity. So the in-series shunt approach with the switch out of the measurement is an excellent fit for higher current ranges.
Offline Kleinstein
For an 1 A current, the drop on the shunt should not be much higher than 200 mV. This already gives 200 mW and thus should use a resistor that is good for something like 2 W or more to limit the self heating. Even for the lower currents, one should get away with less than 1 V - one can still use the same amplifier.
With MOSFETs one can just apply something like +10 V to turn them on. With JFETs one might still need to take into account the approximate voltage levels, as here on is at 0 V and already +400 mV might give considerable leakage to gate. This makes JFETs less convenient in many applications.
For current in both directions one might need something like 2 MOSFETs in series (different direction) because of the substrate diodes. It usually still works just driving the gates.
For low currents a MOSFET with separate substrate or a CMOS switch might be a better choice.
