Question repost
from here (Haven't got answer there, but I'm really curious).
I'm playing around with modified FE-5680b frequency standard (modified to output 60 MHz instead of 1 pps, but I've checked other internal frequencies also, 20 MHz, 30 MHz). I'm using hacked DS1054Z.
So if I trigger on this 60 MHz and then scroll for couple of microseconds then the waveform start to look really jittery, is it a issue with time domain oscillator in the scope ? Or maybe it's a limitation of scope trigger circuit ? I assume frequency standard is named "standard" for a reason
Also exactly the same happens when I play around with cheap AD9850 DDS from ebay.
