Hello
I have an ESP32-S3-WROOM-1U on my PCB.
I used the official footprint from the Espressif github.
Unfortunately, when I render the 3D model of the PCB in Kicad or upload the PCB on JLCPCB, the ESP module est misaligned by half a pin length as you can see on the picture. (Well the pin header also but that's not an issue, it's a through hole component, they will figure it out)
I have verified the footprint and it's perfectly symmetrical in other words I have the feeling that the problem comes from the 3D model of the component and not the footprint.
Now, on JLCPCB there is a way to realign the component, but since I'm quiet sure it's the 3D model and not the footprint that has an error, I fear to correct an issue that finally does not exist in reality on the footprint, resulting in a wrong component soldering.
What do you think?
What should I do?
Thanks
