On headphone output levels.
The headphone spec says, the max power is 1.6W at 1Khz. Is 1Khz likely to be the worst case?
Anyway directly driving the 38 Ohm headphones 7Vrms gives me 1.3W output with 184mA. Sounds awfully high and requires 20Vpp through 38Ohms.
I found this test report for the headphones:
http://reference-audio-analyzer.pro/en/report/hp/audio-technica-ath-m50x.phpWhich gives their sensitivity as 114.6db / V and their Vrms needs for 96db as 0.09Vrms. ~2.6Vpp
I had a read through this as well, on headphone outputs:
http://www.apexhifi.com/specs.htmlI'd like have at least 110db, concert level, but 130db is the maximum.
Using the spreadsheet in the last link, for a sensitivity of 114.6db / Vrms, into 38 Ohms, aiming for 130db, it gives me 912mW, 5.89Vrms and 155mA around 16 Vpp!
Trying something a little lower gives:
110db gives 0.59Vrms - less than 2Vpp
120db gives 5.9Vrms (yes I see the pattern) - ~17Vpp
So it seems due to the log10 nature of things small increases above 110db result in large changes in voltage. So if I go too low I have quiet headphones, if I go to far I have a dangerous (to other equipment) potential voltage on my headphone out.
As BrianHG said, the line level 2.5-2.7Vpp sounds reasonable.... but do I want reasonable? 5Vpp sounds better, giving close to 120db.
Thus, if I keep things around 2.5Vpp from input gain, summer, the headphone amp needs a gain of 2 and the ability to drive at least 50mA. That would be 5 5532s in parallel to be audiophile, 3 would probably work. Or more likely one of those OPAs.
