as a fellow noob, my advice is:
don't be shy to start your own design projects.
there's lots of fun stuff you can do that is quite simple yet satisfying.
my first project was a logic analyzer.
all it is is a probe with 2 leds in it that indicate positive or negative voltage on logic circuits.
very simple project but very satisfying to have made a functional piece of test equipment.
more then anything though: don't be afraid to fail (unless you are working with high power of course
you learn more by failing then you do by success.
Very sound advice. My LED probe was built for 5 V TTL logic. So it was just a test probe, LED and alligator clip. I haven't had occasion to use it in a long time because I haven't been working on anything that required it.
Much of my electronics education was the result of building simple test gear such as a 10 KHz square wave oscillator based on an op amp for testing audio gear. The harmonics go quite high, so with a scope you can get a very good idea of the frequency response. I had very little money to spend on electronics and as I was not an EE student, no access to the labs.
Pick a project that interests you and pursue it until you either succeed or get frustrated. In the latter case, put it in the junk box and start something else. But put it in a baggie with a schematic so you don't have to figure out 10 years later what it is ;-)
Having spent 12 years at university, I became very accustomed to failure. You do it the first time to find out what you need to do. You do it the second time to learn how. You do it the third time to get it done. And if it's really important to you thesis, you do it a fourth time to make sure you get the same result.
Research who Jim Williams was and read anything he wrote, especially "Max Wein, Mr. Hewlett and a Rainy Sunday Afternoon". Same thing for Bob Pease and Bob Widlar.
Have Fun!
Reg
