Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
K8115 component tester
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: K8115 component tester (Read 1051 times)
nForce
Frequent Contributor
Country:
on:
October 06, 2019, 09:42:18 am »
Is this an LCR meter:
https://www.ebay.com/itm/Component-Tester-Kit-K8115/292644257716?epid=10006440206&hash=item4422f4ffb4:g:rJUAAOSwuLZbTc37
Thanks.
Logged
teksturi
Regular Contributor
Country:
Re: K8115 component tester
Reply #1 on:
October 06, 2019, 09:49:48 am »
I do not know for sure but it looks like cheap transistor/component tester
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=transistor+tester&_sacat=0
This looks like way too expensive. If you look lcr-meter look DE-5000. If you look component tester there are many threads in this forum.
Logged
Ian.M
Super Contributor
Reply #2 on:
October 06, 2019, 10:43:05 am »
Velleman product page:
https://www.velleman.eu/products/view/?id=435470
A
steal
at more than double CPC's price:
https://cpc.farnell.com/velleman-sa/k8115/component-tester-kit/dp/MK00592
Its certainly got basic LCR meter functionality, but is likely to be very limited compared to a modern digital LCR meter. It does do ESR, I don't know about ESL or Q. Compare its specs with the DE-5000 just mentioned:
https://www.ietlabs.com/pdf/Datasheets/DE_5000.pdf
OTOH if you *NEED* the semiconductor checking capabilities and you don't buy it from a rip-off Ebay scammer it may be worth it.
N.B. If you have a Velleman HPS140MK2 handheld scope, it may be worth considering the HPS141 component tester accessory:
https://www.velleman.eu/products/view/?id=435690
which, (according to a Velleman staffer) shares the same base firmware and specs as the K8115. Its about 30% cheaper, fully assembled and also available from CPC:
https://cpc.farnell.com/velleman-instruments/hps141/component-tester/dp/IN07745
N.B. the HPS141 *ONLY* works with the HPS140MK2.
Last Edit: October 06, 2019, 11:03:01 am by Ian.M
Logged
Canis Dirus Leidy
Regular Contributor
Country:
Reply #3 on:
October 08, 2019, 12:47:27 am »
Well… If you need just an LCR-meter: Chinese XJW01
cost $65 on Aliexpress
(Assembled variant. DIY kit without case costs half as much).
P.S.
Discussion on forum
DIY kit version review with photos of assembly and soldering order
(in Russian).
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
