Author Topic: Help with USB power switching  (Read 1279 times)
Offline HodgePodgeTopic starter
« on: April 04, 2014, 01:57:21 am »
Hello all!
I am building a small portable music rig to carry around, to run off battery power when I'm on the go, and be able to plug in into a USB socket at home.
Its basically an iPOD, an amp and a DAC and all of them use 5V so that's not a problem.
For aesthetic reasons I am powering them using 4xAA batteries, and I've noticed that rechargables would give me 4.8V and alkalines give me almost 6.0V which I need to regulate to ~5V. Furthermore, if I add the ability to use USB power, I would need some diodes to keep the USB power from trying to charge the batteries. So with schottky diodes, I would additionally have to factor in forward voltage drops... :(
Any help would be greatly appreciated.
Thanks!
Offline mariush
Re: Help with USB power switching
« Reply #1 on: April 04, 2014, 05:24:30 am »
See an IC like this one : http://www.digikey.com/product-detail/en/TPS2115APWR/296-16940-1-ND/652794
Page 16, Figure 14 shows an example circuit exactly for the design you want.
You can use a fixed 5v switching regulator to get 5v out of those batteries, see for example MIC4575 :  http://www.digikey.com/product-detail/en/MIC4575-5.0WU/576-1216-ND/771685
Or LT1376.. it's not cheap but it's in DIP package : http://www.digikey.com/product-detail/en/LT1376CN8-5%23PBF/LT1376CN8-5%23PBF-ND/891357
Have a look at others in the same category (source selector / switch): http://www.digikey.com/product-search/en?FV=fff40027%2Cfff80320&mnonly=0&newproducts=0&ColumnSort=1000011&page=1&stock=1&pbfree=0&rohs=0&quantity=10&ptm=0&fid=0&pageSize=25
