Author Topic: Relays [220V]  (Read 2816 times)
Offline Rihards VeipsTopic starter
  • Country: lv
Relays [220V]
« on: April 03, 2014, 12:47:19 pm »
 I am working on a project at my school for a lighting show in my
city in November.
I will probably be using an Arduino and build something similar to a LED
cube but it will be a transistor cube that will be turning on relays. The
relays will turn on 220V 7W LED lamps, but I don't know what kind of relays I
need. Can anyone help me please?
- Le Nub
Offline electronics man
Re: Relays [220V]
« Reply #1 on: April 03, 2014, 03:18:59 pm »
AC or DC
follow me on twitter @get_your_byte
  • Country: lv
Re: Relays [220V]
« Reply #2 on: April 03, 2014, 03:22:23 pm »
AC
This is the electronics store I buy things from (Relays): https://www.elfa.se/elfa3~en_en/elfa/init.do?toc=18721&name=Relays
Not sure if the link will work...
- Le Nub
Offline madires
  • A qualified hobbyist ;)
Re: Relays [220V]
« Reply #3 on: April 03, 2014, 03:35:01 pm »
Ok, so you want to switch 220V AC. Will each relay switch a single 7W light or multiple in parallel? That way we determine which load the relay has to support. The relay type will be a SPST (Single Pole Single Throw). The next point is the driving voltage, typically 5V, 6V, 12V or 24V. Please choose one based on your power supply.
  • Country: lv
Re: Relays [220V]
« Reply #4 on: April 03, 2014, 03:40:47 pm »
Each relay will switch on 1 light.
Driving voltage: 5V
« Last Edit: April 03, 2014, 03:42:29 pm by Rihards Veips »
- Le Nub
Re: Relays [220V]
« Reply #5 on: April 03, 2014, 04:06:18 pm »
It's very easy to find a relay with your specs
  • Country: lv
Re: Relays [220V]
« Reply #6 on: April 03, 2014, 04:09:59 pm »
Yes, but I don't know if the relays I found are not too powerful(higher price) and I don't really know what kind of relays I need - Solid state or signal ect..
- Le Nub
Offline madires
Re: Relays [220V]
« Reply #7 on: April 03, 2014, 08:44:20 pm »
Please look for power relays. Since you switch just 7W any relay supporting >=1A should be fine, like https://www.elfa.se/elfa3~en_en/elfa/init.do?item=10-573-78&toc=18836.
  • Country: lv
Re: Relays [220V]
« Reply #8 on: April 04, 2014, 01:28:31 pm »
ok thank you :D
- Le Nub
